Fri, Jan 24, 1:50 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 24 1:08 pm)
Subject: V3 trans map woes!!
Foxseelady ( ) posted Tue, 29 March 2005 at 12:27 PM · edited Fri, 24 January 2025 at 1:41 PM
I am trying to create pubic hair for V3; if you have any tips; tricks or tuts to send my way I sure will appreciate it. So far I am using the trans map from daz. It looks right, but won't render with any hair showing on the body. I'm pretty sure I can cut this step by placing the hair on the body template and that would be good....except that then there is still eyelashes and brows to deal with on the trans maps. I am clueless here, I've tried grayscale image, negative image for the trans map. I've also tried it normal jpg. THen I tried color on the object, so far nothing more than a discolored patch has showed up. Oh yeah and I also tried applying the trans as just a trans, and also as material and trans still nutta. So anything will be better than what I've got driving me mad right now lol. Thanks loads.
svdl ( ) posted Tue, 29 March 2005 at 12:46 PM
This may be simple, but, did you apply the PubicHair morph? If that morph is not injected and set to 1, the pubic hair polygons lie just inside the hip, and you can't see it.
My gallery   My freestuff
Foxseelady ( ) posted Tue, 29 March 2005 at 1:19 PM
Omgosh!! svdl that may have been simple but I missed it all together!! woohoo we have pubes now! Thank you so much you've made my day! lol
