Wed, Jan 8, 1:18 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Possible P6 python bug
face_off ( ) posted Mon, 28 March 2005 at 10:20 PM ยท edited Tue, 07 January 2025 at 1:17 PM
Hi All A couple of times now I've had a python script which works in P5 fall over on the following statement in P6 print "ActorName = " + str(poser.Scene().CurrentActor().Name()) If I restart P6, the script then runs ok! I've had someone else report the issue to me too. If I remove the "str()" part, it also works. Has anyone else noticed this?
Creator of PoserPhysics
Creator of OctaneRender for Poser
Blog
Facebook
jeffg3 ( ) posted Tue, 29 March 2005 at 12:36 AM
I believe I've seen it. Very occasionally I'll see it when running your Hyper-real in P6. I've had to do the same thing - quite and restart P6. Seems like the error message was a bit longer though.
face_off ( ) posted Tue, 29 March 2005 at 2:04 AM
Thanks Jeff. What a bummer. Once I catch the full error msg, I'll report it to CL.
Blog
Facebook
an0malaus ( ) posted Tue, 29 March 2005 at 6:29 AM
Any chance that CurrentActor() is returning None, as in nothing selected? You might need to debug it by assigning the function calls to intermediate variables and printing them out. Assuming, of course, that doing so doesn't make the problem vanish ;-) Also, if you're doing a print, it should be able to handle the form: print "ActorName = ", poser.Scene().CurrentActor().Name() without the str() evaluation and string catenation. print can print tuples and dictionaries as well as functions evaluating to None. The inherent assumption (regardless of whether it's a P6 bug or not) of the combined statement is that none of the Scene(), CurrentActor() or Name() evaluations is going to return something that can't be evaluated by the next bit to be parsed - i.e. can't evaluate Name() method if CurrentActor() instance returns None.
My ShareCG Stuff
Verbosity: Profusely promulgating Graham's number epics of complete and utter verbiage by the metric monkey barrel.
stewer ( ) posted Tue, 29 March 2005 at 8:09 AM
In any case, it'd be much safer to check if you really get an object before trying to call methods:
scene = poser.Scene()<br></br>if (scene != None):<br></br>    actor = scene.CurrentActor()<br></br>    if (actor != None):<br></br>        print actor.Name()<br></br>
Python doesn't like it if you try to call functions of a None object.
an0malaus ( ) posted Tue, 29 March 2005 at 8:20 AM
Thanks stewer :-) A code sample is, as usual, the most concise way of illustrating the point I was trying to make: Check before assuming.
My ShareCG Stuff
svdl ( ) posted Tue, 29 March 2005 at 1:14 PM
I often use Python exception handling for cases like this:
try:
print poser.Scene().CurrentActor().Name()
except:
print "No actor selected!"
My galleryย ย ย My freestuff
face_off ( ) posted Tue, 29 March 2005 at 2:16 PM
Thanks for all the comments guys.... Stewer/svdl, my code already establishes that the scene and current actor are != None. The code is failing with a valid actor. In fact the code fails on... print str("hello") So it appears to be the str() function which is somehow becoming corrupted in the P6 session. The issue I've got is that there are a lot of people out there using scripts which have the str(...Name()) coding, and which ALWAYS work on P5. I agree that there is a work-around to remove the str() function - but that doesn't help if I want to convert a numeric to a string. The strange thing is that it works 99% of the time on P6 - it's just the 1% of times that it doesn't work, and you need to restart P6. So obviously there is something in there that is not right.
Blog
Facebook
svdl ( ) posted Tue, 29 March 2005 at 2:21 PM
Oops. It usually works fine and sometimes crashes. No discernible pattern, right? Then it sounds like a memory management error in the C/C++ code. Very ugly bug, very hard to track down.
PoseWorks ( ) posted Thu, 31 March 2005 at 6:08 PM
I prefer using repr(x) for doing convert-to-string operations (just in case str is truly broken, it's a good alternative). Have you tried using str(x)? This will bypass anything that the rest of your code may have done to muck up str.
face_off ( ) posted Thu, 31 March 2005 at 6:26 PM
Thanks for the suggetions PoseWorks. I'd rather the bug was fixed than code around it! But if not, I'll look at your suggestions. Haven't tried str before - will check it out.
Blog
Facebook
face_off ( ) posted Thu, 31 March 2005 at 7:27 PM
OK - i just got the problem again - and doing a File->Reinitialize Python fixed it. PoseWorks - I tried str but it couldn't find the method. I assume I need to input a particular library?
Blog
Facebook
PoseWorks ( ) posted Fri, 01 April 2005 at 5:11 PM
Putting double underscores around some core Python functions will override any changes you may have accidently made, looks like it doesn't work with str though :-/
face_off ( ) posted Fri, 01 April 2005 at 9:48 PM
OK, I can now reproduce the error 100% of the time. Do the following: Start Poser With JamesCasual, run the SSS Wacro in the material room Then run a python script that simply contains the line print str(1) You should get the erro Traceback (most recent call last): File "", line 1, in ? TypeError: 'str' object is not callable Doing a File->Reinitialise Python will fix it (so the print str(1) actually prints 1. Is anyone else able to reproduce the error using the above sequence?
Blog
Facebook
nruddock ( ) posted Fri, 01 April 2005 at 9:54 PM
Just taken a look at the Wacro.
It is using a global variable "str", so this will be overriding the function definition, which is why resetting cures the problem.
Try changing the variable in the Wacro and see if the problem goes away.
face_off ( ) posted Fri, 01 April 2005 at 9:58 PM
Yep nruddock - that fixed it - fantastic. Thanks so much.
Blog
Facebook
nruddock ( ) posted Fri, 01 April 2005 at 10:03 PM
You can fix your scripts by adding the line
from __builtin__ import str
which will bring the function back into scope.
face_off ( ) posted Fri, 01 April 2005 at 10:28 PM
Good point. Although better to fix the source of the problem, than code work-arounds. I've reported the problem to CL.
Blog
Facebook
nruddock ( ) posted Fri, 01 April 2005 at 10:34 PM
I bet you get your update out before they do.
You should ask to them to let you supply a fixed copy of the Wacro to your P6 customers.
face_off ( ) posted Fri, 01 April 2005 at 10:50 PM ยท edited Fri, 01 April 2005 at 10:50 PM
Attached Link: http://www.users.on.net/~pkinnane/P6%20Shader%20Compatibility.html
The fix is detailed at the above link.
And again, nruddock, thanks a heap for the help on this. I've been getting the problem (and reports of it) for over a week and just couldn't work it out!
Message edited on: 04/01/2005 22:50
Blog
Facebook
nruddock ( ) posted Fri, 01 April 2005 at 11:06 PM
I'd been following the thread, but until you whittled it down to using that Wacro, it could have been (almost) anything.
"setLightStyle.py" has the same problem.
The simplest way of curing it would be to move the lines that do the actual work into a subroutine and call that like most of the other Wacros do.
One thought, getting people to edit their copy of the Wacro might cause problems when CL release an updater if it checks file timestamps or sizes.
face_off ( ) posted Fri, 01 April 2005 at 11:10 PM
Mmmmm, good point. I'll check it out.....
Blog
Facebook
