Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2025 Jan 18 5:16 am)
Thank you for the questions and comments. When will it be released? Well, I just sent this to testers, and I am awaiting testing results. As soon as my testers say it's great, I will submit it to stores. If all goes well, I feel it can be released in about 10 days. Does it really load 122 magnets? I have lost count at the moment. But, yes, there are more than 122 magnets in total including those for special use. Thats about how many magents are required to do the complete conversion from tippy toes the neck. They are devided into three groups, Middle body, Upper body, and Lower body. You only need to load the mag sets you need for that particular clothing item. For instance, skirts require only middle magnets, pantyhose require middle and bottom mags, Shirts require middle and top mags. I did the demo .avi on a skirt only to keep the length of the .avi small. thank you marty
mags....mags...mags....how many is enough? I honestly wouldn't have put so many in the package if I didn't think they were needed. This product was disigned to to fit clothing as close and accuratly as possible while working on a variety of clothing. With me, yes I can do an average peice of clothing I am prepairing for the MP with 25 magnets or less. But these magnets span from from neck to toe - wrist to wrist and cover a wide veriety of clothing variation. Also I might add, that I am very detailed and my conversions usually take me probably 2 hours to do a good conversion manually with magnets. This package is designed to make my conversions much more accurate because this method is not just making the clothing fit well, its actually adjusting the facits of the clothing almost exactly in the same place in reference to where the original clothing's facets would be in reference to V3. All these mags gives me accuracy. As a clothing merchant, I still plan to do a little tweaking after doing my conversions this way, but my time will be reduced to 10 min or so of added adjustements and I will have confidenced that my conversions are better now than they were before when I was just doing it soley by eye. marty
Attached Link: Tour and Demonstration of V3-A3 ConversionKit
What this package contains:Three sets of poser magnets and a starter cr2. These together form a kit that can make V3 clothing fit Aiko 3 as quickly as three minutes!!!!
How this package works:
Poser magnets, often under rated or ignored or feared, are a unique and power deformer tool that is included with Poser. One thing very unique about Poser magnets is they only give you the ability to save all your deforming tools and reuse them over and over again. After much refinement, I have created a set of magnets that will deform Victoria 3 clothing into Aiko 3 Clothing. Since grouping in V3 and A3 are identical, there is no need for regrouiping. I have also included a "NewProject.cr2" to use as a quick start loader for poser. With a 2.5 gigahertz processor, one can convert some articles of clothing such as tops and skirts in as little as three minutes. I can convert the V3 Ultra Catsuit in less than 6 minutes.
This product also includes Joint Controlled Magnets to apply to the finished product to compensate for breast movement.
I have worked very hard on this product to serve my purposes as well as yours. I have constucted it as a ultra timsaver for the professional and made it an easy application for the Newbie!
It will work on Poser 4 and above. I will post more about it later, but in the mean time, I have a .avi for download as a zip file at the posted address. The avi gives you a little tour of the product and shows you the conversion of a BATLabs Skirt.
The price of this product will be $20.00.
I am looking forward to your comments,
thank you
marty
