Tue, Dec 24, 12:21 PM CST
Subject: Plant populating
imagist ( ) posted Thu, 31 March 2005 at 7:48 PM ยท edited Tue, 06 August 2024 at 4:33 PM
Hi All is it possible to populate a multi level terrain with plants imported randomly or do I have to position each one separately
wabe ( ) posted Fri, 01 April 2005 at 12:04 AM
What Vue version? What you always can do is to use the "traditional" method with replication. You position the objects you want to replicate high above the terrain, replicate them as often as you want them (with the possible variations) and then use the drop down option for the whole bunch of copies you have created. Ta ta, all sit on the terrains without too much manual work. This was the method we all used before the ecosystems appeared.
imagist ( ) posted Fri, 01 April 2005 at 3:27 AM
Thanks Waltha I am using Vue 5 I have tried it and it has speeded the process this is such a great program Regards Keith
