Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 7:53 am)
Hmmmm. I can run the Tailor 1.5 on my system just fine. I am trying to remember if this is before updating to SP2 or not.
Intel Core i7 920, 24GB RAM, GeForce GTX 1050 4GB video, 6TB HDD
space
Found the answer to my problem (see below). Fortunately the fix was simple. "For some reason the installation of SP2 can cause a file called "AUTOEXEC.NT" to be corrupted or deleted. This file is part of the Windows 16-bit subsystem and usually lives in the system32 folder. What's happening when you get this error is that the setup for that program uses InstallSheild which is a 16-bit program. Since the AUTOEXEC.NT file is missing, it can't run the install program. Not everyone who installs SP2 will have this problem, but we've had several calls and emails about it. Fortunately there is a backup of the file living on your hard drive. Double click "My Computer" then your hard drive (probably C drive) and open the "WINDOWS" folder. Open "SYSTEM32" and see if the "AUTOEXEC.NT" file is in there. Chances are it isn't. If it is, then it's probably corrupt. Arrow up or hit "Back" to return to the main WINDOWS folder. Go down to "Repair" and double click. You should find "autoexec.nt" and "config.nt" in there. Copy these files (Ctrl+C) then go back to SYSTEM32 and paste them there (Ctrl+V). It will ask you if you want to replace the old oneclick "Yes". That should do it. Now try installing that program and it should work fine."
Redon634 Thank you!
space
I'm getting the following error message when I try to install the Tailor purchased from DAZ in the March Madness sale: "H:windowssystem32autoexec.nt This system file is not suitable for running MS-DOS and Microsoft Windows applications". Any ideas? I've also submitted a support question to DAZ.
