oh well - guslaw - now you mentioned my name in a repost - I have no change in simply deleting it (lol) - of course I mean awesome ... or should I update to awful awesome ... - cause what Rena's doing is simply awful - my HD is bursting over with zips d/l from Fairywoods - well well - the only comfort I have is that she's got the same problem with my poses (rotflmao) and maybe one day I have the time to have a look at all her wonderful characters ...
very beatiful.i have 2 agree with Schlabber my hd has gone down in size alot since i found renpads wonderful creations thank you renapd. and thank you Schlabber for all your great poses, that i use every single time i use poser,and not to forget all the other great people here that provide newbies like myself with help and free goodies.
Content Advisory! This message contains nudity, violence
bbs Id=12356 Off the :Topic
<=Form.sess_id=40502878=>
Topic Heading -
Where can I find a application for a "Transparent"
Vickie ?
Where is there a application that can create a "clear" Texture Map for Victoria [in Poser] ?
................It is shown in EVERY layer of Margot for Victoria
Body Texure-with-a utterly-transparency "see-through" rendering..moreover not just opaque WHITE/Light GREY (colourless)placed on top. The challenge is to find or to depicting multiple overlapping surfaces in a single image or Object as if it was totally clear (Face body et al.) Many applications don't have a built in option for creating a "Transparency" where .. in all layers or the face and body texture Even virtual Objects occluding real-world ... So done in such a way where to get a "see-through" Body Texture that's real transparency(all layers of the "entire 'Object'")
.........A render of Vickie transparent surfaces that it appears as clear as pure water not over opaque WHITE (or colourless) where it looks like coloured "glass" just-where just surface is highlighted ?:
PPS -.......ONLY asking in all layers Where can I find an app for a See-through-"Transparent" Vickie ?
It is shown that layers often are used in most Tutorials from off the World Wide Web This is NOT knowing code or having to set parameters
Message edited on: 06/18/2005 16:48
I'm afraid I don't understand your question, but since you are asking about the image here (I assume) perhaps you are wanting to be able to render an imahe of Victoria or whatever and have a transparent background, so that you can stack it on top of other images (as Rena has done in the promotional image above)? If so you need to make sure you have only the elements you wish to see in the scene - most importantly, no background prop - then render and save the image as a Photoshop (PSD), Tiff or PNG file. As long as your imaged editor supports layers you should be able to open the image and it will either have the figure on a transparent background or it will have the figure on a solid background with a saved alpha channel that you can load as a selection to copy the actual figure and add it to a new image - you would need to tell us what you are using to edit your images for us to give you more detailed instructions.
[[MyGallery] [MyStore]
"Collect moments, not things."
