Wed, Feb 12, 10:33 PM CST
Subject: Hm...P6 magnet bugs anyone? :-)
lucstef ( ) posted Tue, 05 April 2005 at 12:26 AM ยท edited Wed, 05 February 2025 at 5:10 PM
Say you create a magnet to create nipples on V3RR left breast, then you set it up until satisfied, finally you load a second magnet on the right breast and start to copy/paste values between magnets/bases/zones... Well, the second magnet gets all the properties if you look at the dial values, but it doesn't move or affect anything!!! Now, select the right breast, zero the magnet channel, and suddenly you see the magnet moves; set it back to 1 and the breast is finally morphed...but everything you do on the magnet then, nothing happens: you must always change the value of the magnet channel on the breast to see what's happening. I must research the matter a bit more deeply, perhaps the problem is in the V3RR figure as other free deformer sets worked correctly with the full V3 figure, but I'll be glad if someone can confirm this behaviour. If confirmed, I'll send a mail to CL (with appropriate screengrabs) to let them know. And no, no "workarounds" please, this is clearly a broken feature and must be fixed :-) P.S. - I checked the nudity flag as I'm talking about "certain body parts", sorry... Ciao, Luca
R_Hatch ( ) posted Tue, 05 April 2005 at 1:25 AM
I'm glad I did this back when I was using Poser 5 then. I just loaded the magnet set I used to add nipples, and then deleted one of the magnets. I added a new magnet, and went about the usual copy -> paste -> convert. I cannot get the new magnet to behave identically to the old one. Glad I haven't uninstalled Poser 5 yet :-/
lucstef ( ) posted Tue, 05 April 2005 at 2:57 AM
So it isn't me...we are two at least. When I'll go home I'll do some other tests to really confirm the problem, then I'll send an email to CL. Thank you :-) Ciao, Luca
lucstef ( ) posted Tue, 05 April 2005 at 2:46 PM
Technical support form sent. As for your test, I saved the two magnets and reloaded them in a new document; same problem, even without deleting and adding a new magnet. We'll see... Ciao, Luca
