Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
Well, have you tried Amapi? Amapi Designer 7 comes with Carrara 4 Pro. Booleans don't always work as expected (you might need to use a union where you'd expect a cut, or something weird like that), but I think it works pretty well. There's always a risk of getting some ugly triangulation or otherwise badly done polygon creation when working with booleans though.
From Carrara basics and Wings to Lightwave and Maya Complete, virtually every 3D program, no matter the cost, has problems with booleans. The reason, I'm told, is that they are all "Surface modelers". Do enough booleans on the same object and something will start going crazy after a while. Form-Z is the exception, it is a "solids modeler" and I watched the Form-Z guys demo their program at Siggraph as it not only did mega booleans and not break a sweat but they actually could go back and move booleaned areas later on. I talked briefly with one of their programmers later and he told that it was because Form-Z worked with solids.
Hi, anyone got experience of boolean models from C4 into Poser? Do they import ok? I'm using Silo for this & having a nightmare!
