Mon, Dec 2, 2:57 PM CST
Vue F.A.Q (Last Updated: 2024 Nov 30 5:12 am)
Subject: Problem with Objects in Vue Infinitie
iloco ( ) posted Tue, 05 April 2005 at 5:04 PM · edited Mon, 02 December 2024 at 2:48 PM
Can I get some of you Vue Infinitie users to see if this happens to you. In your CProgram Files where Vue Infinite installed to add an object folder with some of your saved vob objects and open in vue infinite object icon. You should see and be able to load the new objects. Now go and remove that object or folder and reopen vue Infinite and see if the object or folder is still showing. If it is it will ask you to delete if hit cancel. Ok thats fine. Now close and reopen Vue Infinitie and is it still there. It is for me when I think it should not be there since there is no object or folder. :) Curious what you find. Thanks if you take time to give this a try. iloco
ïÏøçö
martians ( ) posted Wed, 06 April 2005 at 3:23 AM
This works fine for me, although I do need to reselect the removed folder before Vue asks to delete it. (And click cancel to delete? That must be a definite UI no-no!) BTW - Vue 5 Infinite 5.05 Build 275925
iloco ( ) posted Wed, 06 April 2005 at 7:04 AM
Yes that all works as you describe but next time I open vue it shows the objects again for me. Something is not clearing them once I delete them from my object folder and when I delete them when previewing in object window. I am using the later build 276016 with the collection patch applied also.
ïÏøçö
martians ( ) posted Wed, 06 April 2005 at 9:42 AM
Have applied the collection patch and updated to the same build 276016, and it still works fine for me. Just to be clear: Can you actually still load those objects, or is it just the previews that still show?
iloco ( ) posted Wed, 06 April 2005 at 9:46 AM
No I can not load these objects and it says to clcik on cancel to remove from the collection. I clcik on cancel and it removes them from preview window but next time I open Vue and go to objects they are back again. Are you using the objects form my documents or from the CProgram Files where Vue installed to. It is the program Files where Vue installed to is where the problem is for me. I think Deb confirmed she was having same results as me.
ïÏøçö
martians ( ) posted Wed, 06 April 2005 at 10:13 AM
I am using them from the installed program folder, but mine is actually on D: - I don't think that would matter, but who knows...
iloco ( ) posted Wed, 06 April 2005 at 10:28 AM
For some strange reason I think that it does matter. I can put on another drive and it will delte them and they not show once deleted. Weird behaviour.
ïÏøçö
iloco ( ) posted Thu, 07 April 2005 at 11:16 AM
E-on tech support ahve confirmed they can reproduce the problem I am having so it should be fixed in an update. :)
ïÏøçö
