Sun, Dec 1, 9:42 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: P6: SetOuputRes
Ralf61 ( ) posted Fri, 08 April 2005 at 11:44 AM · edited Sun, 01 December 2024 at 9:39 PM
Could anybody bring Scene().SetOutputRes() to work. It simply does nothing - or am I wrong? Thanks for your help in forward.
nruddock ( ) posted Fri, 08 April 2005 at 1:19 PM
It appears to be broken for normal rendering, probably due to the new options that have been added for previewing (I've seen a report of a problem when rendering to a new window).
The equivalent call for Scene().MovieMaker() does work.
Ralf61 ( ) posted Fri, 08 April 2005 at 1:44 PM
Thanks for the info. I think I have to wait for an update. But really don't think they'll fix it.
PoseWorks ( ) posted Mon, 11 April 2005 at 2:05 AM
Make sure you report it to CL's tech support, and there'll be a much better chance of it getting fixed.
