Mon, Dec 2, 2:55 PM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: A way to make a rounded edge without creating lots of polygons
Anthony Appleyard ( ) posted Sat, 09 April 2005 at 12:52 PM · edited Wed, 13 November 2024 at 7:38 PM
See this image of my heli-backpack. The top of the backpack box and the rotor shaft casing join without any real rounding. But in the rotor shaft there is one line of edges parallel to the join, and another in the top of the backpack box. That restricts automatic smoothing on render to a narrow zone around the join, as in the next image. The result looks reasonably like a rounded "fillet" inserted in the join.
Message edited on: 04/09/2005 12:53
mateo_sancarlos ( ) posted Sat, 09 April 2005 at 1:41 PM
Yes, that works well. I recall some guy named Kattman (no longer here, AFAIK) doing a tutorial on it several years ago, in regard to Poser 4.
operaguy ( ) posted Sat, 09 April 2005 at 2:30 PM
could you use this this idea (turn on smoothing but constrain it by stratigically placed edges) to make things like tables more realistic? I hate that "Perfect sharp edge" look on props. ::::: Opera :::::
daveH ( ) posted Sun, 10 April 2005 at 1:43 AM
the term for one or more border rows of polys that help control smoothing is coplanar polygons -- the trick is, as the name implies, that the coplanar polys must lie in the same plane as the face whose shading you're trying to control. in anthony's illustration the coplanar polys can be seen on both sides of the edge connecting the shaft to the top of the backpack. for a sharper edge, use narrower coplanars and use wider ones for a softer edge.
