Tue, Feb 4, 5:51 AM CST
Subject: So Vue Infinite doesn't use Poser 6 files yet?
Marque ( ) posted Sat, 09 April 2005 at 9:35 AM ยท edited Tue, 04 February 2025 at 5:47 AM
Was hoping to uninstall Poser 5...oh well. Marque
agiel ( ) posted Sat, 09 April 2005 at 10:07 AM
It does... but with some limitations. The main one is the new way Poser 6 stores Morph information in a separate, compressed file. If you use this option, Vue will not be able to open your Poser files. But it is only an option - you can turn it off and return to the old way Poser had to store morph info in the main CR2 file.
sacada ( ) posted Sat, 09 April 2005 at 5:57 PM
Move all your Poser 5 runtime files over to Poser 6. Then in Vue, go to options and point to the poser.exe in the Poser6 directory. Rename your Poser5 Directory to Poser5_old and then test run it for a while. If all goes well, you could then uninstall Poser5.
Marque ( ) posted Sun, 10 April 2005 at 8:05 AM
Thank you. Marque
uta41 ( ) posted Tue, 12 April 2005 at 1:44 PM
Attached Link: http://www.hem.passagen.se/ujederstrm/index.htm
I purchased Poser 6 a week ago. I have at present time only Vue 5 prit with Vue's latest update. Has...is it possible to ues Poser 6 with Vue 5 prit? In the folder I received from Poser: Vue 5 prit - Vue 5 Infinitiv???????
uta41 ( ) posted Tue, 12 April 2005 at 1:49 PM
Sorry should be homepage: http://www.hem.passagen.se/ujederstrm/index.html
