Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 27 4:53 pm)
Well, I tried the new drivers. My review is mixed. The Catalyst version was horrible. All kinds of errors, that could not be fixed. So I did a system restore and got rid of them.
I tried the plain drivers then (no Catalyst), and they seem to be working well. The previous version did weird things to my text size. This version restores the text to what it use to look like before. The Poser library looks a lot better. Still too much wasted space, but not as bad as with last month's drivers.
I used to do that, but gave up. Dell takes forever to put new drivers on their page. The ones from ATI work better, and are updated much faster.
And I used to have an Intergraph card. They make great industrial-quality graphics hardware, but just weren't prepared for the consumer market. I ended up using other companies' drivers for my card. (Worked fine.)
I used lat month's catalysts with P6 when it was released, and it works fine here on a ati radeon all in wonder 9600xt I also installed the new ones 2 days ago, and the only issue I had with them, is that they turned direct3d off for some reason.. I turned it back on for gaming, and have had no issues at all. Can't really tell if there's any speed increase, or stability, but this version is the first certified with microsoft in a LONG time...
I just have the latest drivers, xp home, and sr2. (they released 04/05 drivers a few days ago.) Also, don't use that stupid "ati control panel" garbage..grab the smaller of the new driver downloads. I also have my opengl quality set to highest, with no visible slowdown. I'm running a pent 4 2600 as well, with 1 gig ram, and a static 2 gig cache on a different physical HD then my boot drive.
Yeah the Omegas as killer.. they are optimised for gaming, so I don't know if we'll get any more perfomance for P6, since it doesn't even push opengl at all. It might help some with compatibility issues, and the omega drivers are just tweaked versions of the new catalyst drivers, so they are safe to use.
OK I know I should post this in Technical but more of you will see it here.
ATI have put a new version of their Catalyst 5.4 video driver for all Radeon cards. I believe it's a direct response from ATI to the crashes some [including me] have been having with Poser6 and Radeon cards.
The new version that you should install is 6.14.10.6525.
thefixer
poser coordinator
Message edited on: 04/10/2005 04:23
Injustice will be avenged.
Cofiwch Dryweryn.
