Sun, Jan 5, 5:53 AM CST
Subject: Low memory message
Meddo ( ) posted Sun, 10 April 2005 at 8:30 PM · edited Sun, 05 January 2025 at 5:32 AM
Attached Link: http://www.meddo3d.com
Did some got that message when rendering Firefly with Final setting, My System is P4 2.8 G with 2Gig RAm and a ATI Radeon 9800 Pro 256 Meg.
Meddo
www.meddo3d.com
www.endless-studios.com
randym77 ( ) posted Sun, 10 April 2005 at 8:41 PM
Yes, I get that all the time. Even if I have only one figure in the scene. Then it nukes the file. :-(
akura_ ( ) posted Sun, 10 April 2005 at 9:56 PM
Same here. Hope curious labs finds a way to fix this.
XENOPHONZ ( ) posted Sun, 10 April 2005 at 10:34 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=2201426
You've been bitten by the infamous P6 Memory Bug.
We've already had a couple of dozen or so threads about it.
Here's a link to one of them.
Hopefully, the first service release will repair the problem.
Otherwise, Poser 6 is severely handicapped in what it can do.
Here's another thread on the subject:
http://www.renderosity.com/messages.ez?Form.ShowMessage=2202759
Something To Do At 3:00AM
thixen ( ) posted Mon, 11 April 2005 at 9:15 AM
I got that a couple times as well. Running a process killer (like EndItAll) helped a good bit, but that's because you're having more memory to start out with, and has nothing to do with acctually fixing (avoiding) the bug, it just delays it. In my case it delays it until the render is over, but I'm sure if I made some really big complicated renders I'd still run into it.
cspear ( ) posted Mon, 11 April 2005 at 9:25 AM
I get this, usually when the FireFly engine is set to its top quality settings. I have found that regularly defragging and optimising my hard drives, and making sure that nothing else is running, minimises the occasions when this happens. But it still happens...
PoserPro 11 - Units: Metres
Adobe CC 2017
Naladae ( ) posted Mon, 11 April 2005 at 10:55 AM
I've found that setting the bucket size down to 8 seems to help most of the time - I've had several scenes which generated the above message, then rendered just fine when the bucket size was cranked down that far.
akura_ ( ) posted Tue, 12 April 2005 at 3:12 PM
I render with a bucketsize of 64 with no problems. It has to do with lights.
Meddo ( ) posted Tue, 12 April 2005 at 6:43 PM
I send the bug to Curiouslabs they reply with several question (normal) , and all the information was pass to the engineers and they are working on it.
Meddo
maybe a service pack.
www.meddo3d.com
uli_k ( ) posted Tue, 12 April 2005 at 9:38 PM
Hi all, please understand that there is a distinction between the general case of the FireFly renderer running out of memory and the particular problem of a scene file getting corrupted on saving that some people report. The settings labeled as final are very aggressive in terms of resource needs. It is possible that at such render settings, a complex scene consumes more memory than an application can use on a 32 bit Windows system (2 gigabytes). That's why there is a memory check during rendering and that's why there is a message that suggests lowering those settings. This is all normal operation of the application. Please also consult the FireFly rendering tutorial in the Poser 6 Tutorial manual PDF for details on this matter. If you experience that lowering the render settings doesn't help, if your scene is not complex (100,000 polygons or less, no 4k by 4k textures) or if you are affected by Poser writing a corrupted scene file, then that is not normal and considered a bug. In that case, Curious Labs tech support would like to talk to you. Please make contact through http://www.curiouslabs.com/article/articleview/18?sbss=435. Thanks a lot, Uli
