Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 08 12:39 am)
You can use the Tailor (available at Daz) to transfer morphs from the figure to the clothes. I assume you make your priest by applying a morph you made to M3? If so, then save a cr2 of M3 with the priest morph, then use the Tailor to transfer the morph to the priest clothes.
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
The catch is that The Tailor doesn't always do a perfect job of transferring morphs, especially when the morphs make the figure smaller. You may be faced with some tidying up after it's done its job: but it should still be quicker than doing the whole thing by hand. If you're making clothes specifically for a morphed character, it's better to use that morphed character as the base for the modelling, not the default character shape.
I've been looking for a Priest and an Altar Boy for ages now. Finally I settles down to make my own. I modeled them around M3 and the PreTeen Male. Where do I go from here? How do I make them morph? For example, I used M3 to make my briest, who is thin and frail but uses the same mesh. I modeled the priest around M3, not the priest (stupid on my part...) How can I apply morphs to the uniform to make it fit my Priest? Thanks!
