Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 9:10 pm)
You can import a AVI video as a background. Scrub through the timeline, and you can see the video move, and animate the characters accordingly.
Message edited on: 04/11/2005 02:07
Tools : 3dsmax 2015, Daz Studio 4.6, PoserPro 2012, Blender
v2.74
System: Pentium QuadCore i7, under Win 8, GeForce GTX 780 / 2GB
GPU.
Do you mean creating a render for compositing into an image of a doorway? Is this also for animation? There's no way that I'm aware of in Poser, be it features or material tricks, that allows you to "occlude" certain portions of rendered objects in this way for compositing purposes. The way it's done in other apps is with special "matte" composite materials. You would basically insert a "mock up" of whatever object is in your background image into the scene, then apply a special matte material to it, which would render invisible, but also occlude objects behind it for seamless compositing. Poser simply doesn't have this. You can, however, make objects into "shadow catchers" for compositing shadows, if you have P5/P6.
v2.74
GPU.
If you render to a file format with alpha channel intact, then all you need to do is composite it with the original movie in post. It's better that way anyway. To answer your question, though... check to make sure "render over" is set to 'background picture' in your render settings. If it's set to 'background color', then that's what it will render.
v2.74
GPU.
Hi,
I am new to Poser. What is the best way to place an animated model created in poser over video? I am not sure if poser has the feature, but it would be great if I could see the video on a timeline within poser, so I could position the characters according to the video background. Is this possible? If not, how do I do it? Do I need other software.
Kind regards,
Mil
