Mon, Feb 17, 1:30 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 16 10:02 pm)
Subject: Python (or other) script request.
AntoniaTiger ( ) posted Tue, 12 April 2005 at 8:46 AM · edited Mon, 17 February 2025 at 1:16 AM
The way Poser works, the Deltas for a morph take up a lot of space in the .CR2, and I often see them with 7 or 8 decimal places. That works out as tiny fractions of a millimetre, and seems excessive. It's often much more precision that the .obj file stores. Is there a Python script (or Perl or Awk or similar, but Poser has Python included) which can truncate this data? When a Parameter velue of 1.0 shifts a vertex by the Delta value, can anyone see the effect of that 7th decimal place? And sometimes you get a burst of scientific notation; 7 or 8 significant digits with an exponent. 1 part in 10E12?
ockham ( ) posted Tue, 12 April 2005 at 9:11 AM
Here's a quickie that cuts precision to 4 places. Saves the result as *.CR2.XXX to make it obvious in directory; I didn't want to make it something like *Mod.CR2, because that could be a real file.
My python page
My ShareCG freebies
ockham ( ) posted Tue, 12 April 2005 at 9:12 AM
Forgot to say: this mods the 'v' lines as well as the 'd' lines. Most CR2s don't have 'v' lines, but a lot of mine have internal geometries....
My python page
My ShareCG freebies
AntoniaTiger ( ) posted Tue, 12 April 2005 at 10:28 AM
Thanks. I did a little test with the other problem I see. Some values are of the form: 1.2345e-005 Poser 5, at least, has no problem with the form: 1.2345e-5 Only 2 bytes per value, but it was over a megabyte from the CR2 I tried it on.
AntoniaTiger ( ) posted Tue, 12 April 2005 at 11:05 AM
Now tested... Set to the default, it trimmed 7MB off a 31MB .cr2 That may be excessive. Some of the morphs did seem to lose a little definition. One or two, such as NavelGone, do need more precision. Nevertheless, it pretty well works as advertised. Thanks again.
ockham ( ) posted Tue, 12 April 2005 at 11:08 AM
If that's too much, try changing the 4 to 5 as mentioned in the comments at top....
My python page
My ShareCG freebies
EnglishBob ( ) posted Tue, 12 April 2005 at 11:32 AM
25 minutes from request to fulfilment - that's impressive... Thanks Ockham, I've been looking for something like this. I think Dodger had a Perl script once that did the same thing, but I could never be bothered to install Perl just for that.
ockham ( ) posted Tue, 12 April 2005 at 12:01 PM
That's the advantage of experience.... having lots of templates floating around, which can be quickly modified to serve a new purpose. The disadvantage of experience is the tendency to say "Oh, I know that won't work." A beginner starts with the assumption that everything is possible, so goes ahead and tries it.
My python page
My ShareCG freebies
AntoniaTiger ( ) posted Tue, 12 April 2005 at 12:38 PM
Yes, 5 decimal places seems to work. Possibly not so good for close-ups, but since Aiko and Hiro (the recent/new DAZ anime figures) don't use morph INJ/REM methods, saving over 10% on each figure is a useful improvement.
face_off ( ) posted Tue, 12 April 2005 at 4:16 PM · edited Tue, 12 April 2005 at 4:17 PM
Wow - this is fantastic! Thanks ockham. I assume it's valid to do this for pz2 and pz3 files too?
Message edited on: 04/12/2005 16:17
Creator of PoserPhysics
Creator of OctaneRender for Poser
Blog
Facebook
ockham ( ) posted Tue, 12 April 2005 at 4:44 PM
Hmm... Yes, I guess you could. The 'v' and 'd' lines are the same. The file-open dialog looks for CR2, but you could either change that or just type in a different name. Nothing after the file-open is CR2-specific.
My python page
My ShareCG freebies
AntoniaTiger ( ) posted Tue, 12 April 2005 at 5:13 PM
I just flicked through a .obj file, and it looks as though it would work on that too. The same "v " lines. You could probably cut back a "vt " line too -- is that the UVmap data? -- but it only has two values.
byAnton ( ) posted Wed, 13 April 2005 at 2:09 AM
Cool stuff. I love threads like this. Kudos to Antonia and ockham. Anton Kisiel
-Anton, creator of Apollo Maximus
Over 100,000 Downloads....
ryverthorn ( ) posted Fri, 15 April 2005 at 11:37 PM
this is great! it's just what I needed! I was able to get a 6.3 mb file down to a 4.7 mb file with no morph quality loss... I am one happy camper here! thank you very much! :-)
