Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 04 8:39 am)
I too could use a tutorial on placing/using lighting. Was trying to do a render of the Mil Dragon in it's free lair from DAZ, and with the lights outside the lair (or I assume that's the problem) I get a black render inside. Not sure how to go about actually seeing where the lights are located, etc.
John
Once upon a time I made a "point" light for P4. It was a bunch of spots hooked to a prop. All the light controls were linked via EMC to the prop.
Very slow, very cumbersome, and very buggy. Which is why I never released it. But if you want to try it drop me an email and I'll see if I can find the file.
nerd@nerd3d.com Nerd3D <-- Can't spell
Message edited on: 04/13/2005 12:50
Round object instead of square (only in the render, I assume): uncheck Smooth Polygons on the object property sheet. You could also uncheck Smooth Polygons in the render settings dialog, but that's a global setting and you might want to be able to smooth objects that should be round (like Victoria 2's shoulder). And about lighting setups if you don't have point lights: I usually use a set of 6 spotlights, 4 on the corners of a square around the fire, 1 above and 1 below. All with the same color, intensity settings, falloff settings, all pointing at the center of the fire. Works pretty well - and if you add smoke, the smoke will be lit up nicely too. I usually parent the lights to the fire prop.
I'm not sure where it is, but somewhere I found free something called "ultimate fire". it might be in the freebies section, but I dont know. It comes with a candle prop, but you can ignore that and just use the lights. The lights are set up to look like the glow of a fire. I'm sorry I dont remember where I got it though.
Attached Link: http://fnproductions.net/graphics/tutorials/poser6
Head over to the AO and lighting issues....look for probe light.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
