Didn't have to delete. Just select the object that you want to unparent, and choose the "figure parent" button, just as if you were about to choose a parent. The hierarchy window will open as usual. Instead, choose nothing at all, and close the hierarchy window. The process cancels any previous parenting, and your parented object is now unparented. Orphaned...
Abortion? Seriously (IIRC) 1) Take the item that screwed things up and Parent it to the Universe (or to nothing; same end result, IIRC). 2) Take the invisible figure and restore it's parenting to what it originally was (you may have to re-position it first). 3) Re-parent the ax to the CORRECT figure's hand (I THINK you parented it to the hidden figure - I've done that myself with similar results, but I usually wound up screwing something ELSE and had to start over...).
