Thu, Jan 9, 12:48 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 09 12:26 am)
Subject: Wireframe rendering
VacuousSapient ( ) posted Wed, 13 April 2005 at 6:08 AM ยท edited Thu, 09 January 2025 at 12:46 AM
Poser 6 I have posted this question here before and wanted to try again. I want to render a PNG file of the wire frame image. I can do this, however, the detail is too much. It gets so complicated that the wire frame actually looses the detail and meshes around the complicated parts like the face. It becomes difficult to see the actual detail of the wire-frame. Is there a way to render the wire frame and keep it simple? A good example is the face shown as Poser 6 loads. I just want a full figure view. I can render the wire frame figure using the settings: Image File Preview Antialias Resolution Full View Single Frame Movie Thanks,
EnglishBob ( ) posted Wed, 13 April 2005 at 10:42 AM
You're getting a complicated render because the model IS complicated - no real way around that. You could use a lower resolution model, but here's an idea: why not make your own wireframe map? This could be based on the figure's actual wireframe, or it could be something fanciful. Use the map as a transparency map, and you're in control; it can cast shadows, and you don't have to mess around with single frame movies.
anxcon ( ) posted Wed, 13 April 2005 at 12:08 PM
just use texture template, edit it and remove some of the lines then plug it into mat room nodes n done :)
SAMS3D ( ) posted Wed, 13 April 2005 at 4:56 PM
This is interesting. Gotta try this one...Sharen :-)
VacuousSapient ( ) posted Wed, 13 April 2005 at 5:04 PM
I am attempting a few of these. I am by no means an expert in Poser. I used Poser when it was first production release and have not touched it until 6. I am looking through the texture template and have no clue as to how to remove lines. I miss-spoke above, I do not render to a file format, I render and export to a PNG. Here is a nice example of what I am trying to do. They were able to get a 3D rotate view in Flash. http://www.myss.com/chakrasflash.asp Thanks
VacuousSapient ( ) posted Thu, 14 April 2005 at 4:17 AM
I have attempted going through the Reference and Tutorial manuals and they lack in detail. Are there any good books out there? I am at Poser 6. Thanks
EnglishBob ( ) posted Thu, 14 April 2005 at 4:46 AM
That looks very much like Posette (P4 nude woman) - you could try using her. I think she's still available in P6.
