Thu, Nov 14, 2:15 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 13 11:02 am)
Subject: What the %$#@&* is going on with my libraries????
Butch ( ) posted Thu, 14 April 2005 at 7:54 AM · edited Thu, 14 November 2024 at 2:14 AM
I am running P5 and just started to get this problem this morning. What is going on and how do I fix it. This the message I get when I try to open any of the Library folders....
randym77 ( ) posted Thu, 14 April 2005 at 8:17 AM
Is the that folder there when you look for it using Windows Explorer?
Butch ( ) posted Thu, 14 April 2005 at 8:22 AM
those are the correct pathways to the poser files. I used the default installation and have never changed them to anything else. It makes it easier that way or so I thought!
Birddie ( ) posted Thu, 14 April 2005 at 8:27 AM
are you sure your path is correct? Poser usually only does that if something is messed up & can't find the correct path to the files.
randym77 ( ) posted Thu, 14 April 2005 at 8:28 AM
Yes, they are the correct paths, but does the folder still exist? Can you navigate to it using Explorer? It may have been accidentally deleted or damaged.
Butch ( ) posted Thu, 14 April 2005 at 8:32 AM
The folders are there. I don't have a problem going to them using IE. All my files are in the folders, P5 just can't seem to find them. I don't know what happpen. Last night P5 worked fine. I closed the program and went to sleep and woke up to find this mess! I really don't understand this error at all. I wonder if something happened to the P5 exe file so that it can't find the files....
randym77 ( ) posted Thu, 14 April 2005 at 8:53 AM
Could be. I've found I have to reinstall Poser once in awhile; it tends to get corrupt over time. Also check and see how much free space you have on your hard drive.
Butch ( ) posted Thu, 14 April 2005 at 8:55 AM
83 gigs of free space so I don't think that is the problem. Going to reload poser and see what happens....
aryeguetta ( ) posted Thu, 14 April 2005 at 9:04 AM
Hi, Does the same problem occure also in the RUNTIME library Not in the Download folder? As far as I know there is a limit of CHARS in the path to a file(not sure how many) can you copy the Pose directory to your RuntimeLibrariesPose Not in Download and try loading the Pose from there. Once I hade a problem with a figure and I went delete the RSR file for the Geometries OBJ file and it fix it - BUT you have a problem with pose.... I'm not sure how this can help. Try ReInstall Poser thats what I think will help Regards, aryeguetta
gillbrooks ( ) posted Thu, 14 April 2005 at 10:03 AM
Looks to me like you deleted the 'Downloads' runtime that poser installed. Poser doesn't like it when you do that. It turns green and it turns angry. Just put the Downloads runtime back and all will be well. Even if you don't use it, it has to be there.
Gill
Butch ( ) posted Thu, 14 April 2005 at 10:39 AM
Hmmm, I did delete folder. It was just sitting there empty and I hate empty folders on my harddrive. It is so messy. Going to try that now. Thanks Butch
Birddie ( ) posted Thu, 14 April 2005 at 11:16 AM · edited Thu, 14 April 2005 at 11:17 AM
'cannot find' can mean so many different things. You keep having to guess what Poser can't find most of the time. Process of elimination works wonders. ;)
Message edited on: 04/14/2005 11:17
Butch ( ) posted Thu, 14 April 2005 at 12:00 PM
Well I got P5 to run again and find the libraries. I had to copy my entire Runtime folder into the Downloads folder to do. Now, I'll go back and slowly delete things out of the Download folder. I shouldn't need to have two complete runtime folders of the Same thing in poser to make it work!
akura_ ( ) posted Thu, 14 April 2005 at 4:15 PM
I managed to get taht fixed by unziping a poser item into the runtime, the error missages went away.
nruddock ( ) posted Thu, 14 April 2005 at 4:29 PM
You must have deleted the directory while it was still selected as the current Runtime. When you started Poser again, it tried to create the normal library folder structure (it does in each Runtime you link) and couldn't hence the create errors.
randym77 ( ) posted Thu, 14 April 2005 at 4:30 PM
You can't delete the Downloads runtime. Even if it's not the current runtime, Poser will be very unhappy if you delete it.
