Tue, Feb 4, 5:47 AM CST
Subject: Has anyone used Irina + adventuress yet??
zarquen ( ) posted Fri, 15 April 2005 at 4:48 PM · edited Tue, 04 February 2025 at 5:42 AM
Hi. I've purchased two great products: Irina (for steph3) and aventuress clothes for her, both by Blackhearted and Rio. I fount it's so wonderful that I'm using'em massively. Problem is that the rest of Steph clothes I own doesn't fit correctly on her because of her body morphs. I found a set of freebie deformers for applying on any cloth; the problem is that I havn't mannaged to apply them. Has anyone tried it? Any clues/hints? Does it work on DAZ S3 Jersey set? and in DAZ SP Medieval Fantasy Dress? Many thanks in advance.
Marque ( ) posted Fri, 15 April 2005 at 4:54 PM
Tried them on a SP set, the pants fit but not the top so I don't know if I did them correctly. Going to try again later this evening. Marque
Arien ( ) posted Fri, 15 April 2005 at 5:35 PM
I've been able to add the Irina morph to both the MFD and The Dress using the Tailor, and everything worked quite well. I still need to add them to a few other items I have. The only time when the Tailor didn't work was when trying to get a converted item of clothing to get the new morphs. Boy, was that nasty. Anyway, I think they set is fantastic, I'd barely use SP before getting those, and now I find myself alternating between her and Aiko as my main figures.
My store
Marque ( ) posted Fri, 15 April 2005 at 10:36 PM
Think you could do a quick tutorial on how you added the morphs? Thanks, Marque
blue2000 ( ) posted Fri, 15 April 2005 at 11:07 PM
Very good product works ok for me.
Marque ( ) posted Sat, 16 April 2005 at 1:16 AM
I have ver 1.5 of the Tailor, and haven't messed with it since it came out originally here. I pulled in the Irina character and pulled in a SP3 top. But having a problem transferring the morphs. Every time I check one it tells me 0 morph selected. Can someone give me a hand with this? Thanks, Marque
Marque ( ) posted Sat, 16 April 2005 at 1:19 AM
Think I figured it out....fingers crossed. Marque
Coleman ( ) posted Sat, 16 April 2005 at 1:35 AM
I haven't tried Tailor on Gen3 DAZ people either yet...maybe you have to inject the morphs into the character than save it as a cr2 and use that as the base for Tailor to work with...I'm not sure yet. Irina's body morph is great :D
Marque ( ) posted Sat, 16 April 2005 at 2:01 AM
Whoa, the Tailor is pretty cool. I'm impressed. Marque
Marque ( ) posted Sat, 16 April 2005 at 2:02 AM
Need to play with the dials more but I'm happy with the Tailor. Marque
Marque ( ) posted Sat, 16 April 2005 at 2:07 AM
Little better
Marque ( ) posted Sat, 16 April 2005 at 2:09 AM
Do you have to exit Tailor and start over for each piece of clothing? I tried reloading the figure but the clothes are still in the window. Thanks, Marque
elizabyte ( ) posted Sat, 16 April 2005 at 2:15 AM
I tried use Tailor on Luke and Tailor crashed every time. If I loaded the model without any morphs, it was okay, but there's not much point in that... bonni
"When a man gives his opinion, he's a man. When a woman gives her opinion, she's a bitch." - Bette Davis
Aeneas ( ) posted Sat, 16 April 2005 at 2:57 AM
Not to make any other merchant jealous, but ever since I bought Blackhearted's Ki quite a while ago, I was impressed with the original approach, and Irina is no exception to this. This said, I don't have the Tailor (something makes me a bit suspicious, dunno why) so she'll have to stay in exotic regions for now as I only have a bikini. Or I should start doing a lot of points tweaking...
I have tried prudent planning long enough. From now I'll be mad. (Rumi)
Marque ( ) posted Sat, 16 April 2005 at 3:06 AM
Here is the Cygnus outfit. Marque
Marque ( ) posted Sat, 16 April 2005 at 3:10 AM
Ki isn't sold anymore? Marque
Marque ( ) posted Sat, 16 April 2005 at 3:13 AM
Can I share the morphs somehow? Don't want to violate any copyrights, is there a way to just copy the morphs so that the people who need them have to have the outfit to use them? Thanks, Marque
AntoniaTiger ( ) posted Sat, 16 April 2005 at 4:53 AM
There may be a way to make a stripped down .cr2 file with little more than the morphs, which can be transferred using Morph Manager. I've seen something like that, but I'm not sure where. A .obj file containing a morph just needs the v-lines, not anything else, an array of points. Copyright, I think you have to check what the original owner has to say about what you can do and how.
Marque ( ) posted Sat, 16 April 2005 at 8:58 AM
Thanks. I remember Ki now, still have her but had to re-download her. Will have to try the Tailer on her. So many chars that got put aside for lack of clothing...lol Marque
