Sat, Dec 28, 4:24 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 27 9:24 pm)
Subject: P6 & Injection Magic
mysticwinter ( ) posted Fri, 15 April 2005 at 11:52 PM ยท edited Fri, 27 December 2024 at 12:21 PM
Has anyone saved a morphed .cr2 figure from within P6, brought it into Injection Magic, then tried to apply the .inj file to the figure? I did, P6 just closed on me :o( is it for the same reason Tailor throws a fit? the center mass etc.. stuff? or is it just me. Thanks Mystic
wdupre ( ) posted Sat, 16 April 2005 at 3:19 AM
Im guessing the problem came up when you resaved the morphed cr2, Poser 6 saves external morph data by default, so the new cr2 will not be injection compatible. try turning off "Save external morphs" in your prefrences and than retry your morph setup from the original base figure.
mysticwinter ( ) posted Sat, 16 April 2005 at 2:55 PM
I do have the 'save external morphs' turned off.. :o( Thanks Mystic
ChaosDrgn2 ( ) posted Sun, 17 April 2005 at 6:44 PM
I've done it with M3/V3/David and haven't had any problems with IM and P6.
mysticwinter ( ) posted Sun, 17 April 2005 at 7:39 PM
okay, thank's for the reply. I must be doing something wrong.. I'll figure it out :o) Thanks Mystic
ChaosDrgn2 ( ) posted Sun, 17 April 2005 at 8:07 PM
Well I have the PNM b.s. turned off, plus I have it all in one directory instead of multiple runtimes.
mysticwinter ( ) posted Sun, 17 April 2005 at 8:46 PM
hmmm... I have multiple runtimes.. the only difference I can think I would have done from P5 is my !daz stuff isn't in the main runtime anymore and I was saving to another runtime.. if that makes any sense LOL going to correct this and try again.. Thanks, Mystic
