Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 12 3:30 am)
OK, make sure that you have Body selected on one of the hires figures... choose a morph style... click on the dial and move it or type in a number. Look at the figure and it will be changed. These morphs are best used in small amounts (.5 or less). You can go in and tweak arms or chest or whatever individually, but this gives a raw starting point for a more muscular or skinnier or fatter person. I would only use it as a starting point, though. Typing in large or negative numbers can lead to amusing results and might also be a good jumping off point for aliens and mutants. Carolly
The Endo Ecto and Meso morphs have been setup to work from 0 to 1. Unfortunatly there is a double effect on the hip and chest of Jessi's FBM's which leads to unpredictable results. I am sure that this issue will be amended in a forthcoming content service release but currently to resolve this issue heres what you do,
For arguments sake if you have Genitals ON and have set
BODY:EndomorphFBM to 0.3
you will have to set the
chest:EndomorphNoGenFBM to -0.3
hip:EndomorphNoGenFBM to -0.3
If you have Genitals OFF and have set
BODY:EctomorphFBM to 0.8
chest:EctomorphFBM to -0.8
hip:EctomorphFBM to -0.8
I am afraid I am being awfully dense, but as I am trying to work through the new stuff in P6 I can't figure out what the endomorphs and ectomorphs included with the new P6 figures do or how I am supposed to use them? I would appreciate some advice. Thanks in advance. Dore'
