Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 03 8:14 am)
Thanks. It helps indeed. But there's something my little rey cells can't grasp. I mean: BH started with a mesh and changed settings of individual points. So, if you can change to another headmorph like that, one that does use the Daz injection morphs, it means that these do not take into account the original place of the points, but only their correct number. Then why, when changing from one character to another, both with Daz injmorphs, do you have to reset the original face first?
I have tried prudent planning long enough. From now I'll be mad. (Rumi)
you should have just emailed me :) i dont browse the forums much so i only accidentally stumbled upon this thread. im pretty sure this is in the readme. you can just select the head and turn the irina morph to 0, and then inject whatever SP3 morphs you would like. it is all injected together, for simplicity's sake, but then you can just dial down the morphs however you see fit. if you wanted to, you could create something halfway between irina and SP3 by turning all of the irina dials to .5000, and then even furthher customise it by injecting and dialing the SP3 body morphs.
Poser5, Stephanie Petite. I have Blackhearted's Irina, but I would like to change the head. As you know (or don't if you don't own a copy of the product) body and head together are one full bodymorph. Unfortunately I cannot inject the head separately from the body. How would you attack this problem: changing the head for SP's basic head by using it as a morph (risk the neck won't fit) or manipulating the text (numbers) in the file? Or? thanks!
