Attached Link: http://www.senosoft.com
No this is not normal. This could be: 1/ A textured PZ3. Textured figures generally have white colors. To see it textured check Render | Texture mapping. 2/ Missing textures, you can check textures path from the Information (Awk) tree. 3/ A bug in the Poser parser. In which case please contact me at lac@senosoft.com, I'll fix this (I'll probably need the PZ3, without OBJs or textures to find the prob). I can help you fix that problem. Don't hesitate to contact me for more explanations or details. Yarp btw Only P3dO pro is able to show PZ3s btw P3dO 1.7.7 (freeware) will be released next week ;)Yarp - author of P3DO Organizer for Poser
Bonjour just another question about P3Dpro:can i use it for clean my older runtimes: list and possibility to delete cr2 but also indicate and eventually possibility to delete where the files(geometries,textures) associated with this cr2? I know the shareware can indicate some files but i have seen that somes are not indicated and when you want to delete some inside P3DO browser its take long time to do it IS pro version better to do this ? Thanks
Hi martial,
The pro has a Awk plugin addon called Scene Manager which adds a Delete Scene menu entry in your Tools and Awk popup menu. You can see what Scene Manager looks like on my home page (www.senosoft.com), bottom left.
Delete scene offers to selectively remove the files you want from the disk.
Scene Manager doesn't improve the number of listed files, nor does it has to see with the loader performance. This has to see with the Poser Parser I was talking in my first answer.
I'm aware of the fact the Parser is a bit slow but I've had ideas on how to improve the speed. This'll be done with the June update (1.8). The freeware has the same engine so you'll be able to compare the speed improvement.
Regarding missing files don't hesitate to report any oddity, possibly on publicly available figures/CR2, and you can be sure I'll fix this.
Last, the scene manager will drastically change in 1.8 and I bet this will be a killer function for such needs.
So I should say that at the moment the pro does offer the way to remove a scene much quicker but is far from being perfect. The June version will solve this, except maybe for the complete list of files since I need to experiment the bugs to fix them.
Yarp
Message edited on: 04/20/2005 05:17
Is there a way to see the PZ3's in color??? All I see are B&W images...like a naked model with no mats. Is this normal??? Or have I missed something? TIA
