It is a rendertime error in the code. When two identical trees (as may happen with duplicates and clones) visually overlap (from the camera POV) bryce gets confused and may produce such artifacts. I did a serious set of research into this about tywo years ago (still might be able to find the thread though). The solution is to select one of the affected trees and just tweak one of its settings so it is no longer identical - bryce then ceases to get muddled!
Thanks a lot I will try to change the tees and get away form the duplicate trees. I think it might have to do with the volume materials too because I did not have this problem beforeI think the volume materials did nto encompass the trees. It was redered at 16 rays I don't wantto go higher. I will try to change all the trees a bit ansd see how that goes. Great info here. Thanks.
The wit of a misplaced ex-patriot.
I cheated on my metaphysics exam by looking into the soul of the
person next to me.
@incarnadine I don't follow "tweak one of its settings" you mean randomness or gravity? Sizing does nothing. @ Quest I don't think it's a metaball issue at least it doesn't behave as a normal metaball would when it nears another, althought the missing chunks do seem to deminish the further the clones are spaced. I originaly gave up on it although the desired effect seemed feasible
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1228371
Found it! BTW I usually tweak the random. You are correct in that changing scale does not really change the identicalness.Pass no temptation lightly by, for one never knows when it may pass again!
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=938033
Hey here is a rerender with a few small changes. Thanks for all the help. Soemthing new every day here.The wit of a misplaced ex-patriot.
person next to me.
I cheated on my metaphysics exam by looking into the soul of the person next to me.
