Thu, Dec 26, 7:40 AM CST
Subject: Texture Stretching Distortion (A remedy?)
ExprssnImg ( ) posted Wed, 20 April 2005 at 9:30 PM ยท edited Thu, 26 December 2024 at 7:36 AM
I bought this 3d model for Poser. I wanted to re-texture it because of it's horrible texture stretching problem but I still can't seem to defeat the problem. Is it possible to export it to cinema 4d, increase the polygon count on it, then get it back to poser? It's an organic creature so I realize why it happens, I just was wondering if there is a way to get around the problem without involving too much headache?
stonemason ( ) posted Wed, 20 April 2005 at 9:51 PM
increasing the polycount won't make your uv mapping any better. what are the uv mapping features in Cinema like? Stefan
Cg Society Portfolio
ExprssnImg ( ) posted Wed, 20 April 2005 at 10:16 PM
Well I usually use Cinema for setting up scenes and lighting but have been slow learning on the uv mapping and such. I usually use the Poser maps given or make my own. You can do different types of mapping, front, cyllindrical, spherical, box, but nothing maps like a uv map. I don't know of a way to adjust it. I just learned something about body paint but I haven't been able to paint texture on yet.
Aeneas ( ) posted Thu, 21 April 2005 at 2:13 AM
The problem can easily be understood. Compare it to opening a pic of, say, 100x80 pixels and blowing it up to full screen. You will see pixels. The quality will deteriorate. That same thing can happen with UV. When you model something, as you well know, you get polygons whose size and placements are decided by the points on their corners (vertices). An uv map of your object has the same number of polyons and points/vertices as your model, and each point corresponds with one on the polygon mesh. U corresponds with the x-value, and V with the Y value. (z, the depth, is in this case not used). Now when uv coordinates are flattened out on a map, some distortion occurs. Like flattening the earth and seeing the continents on a map: some continents are larger than they really are, and some are smaller. In your case, some polygons on the map can be much bigger than they are, and some smaller. When now, on your map, you apply your bitmap image, the larger uv polygons will get a larger piece, and the smaller ones a smaller piece of your bitmap. When seen on your object, those polygons have the same size, yet some will have more of the bitmap texture than others. This is, simplified, the case. The remedy is more complex. If you own Bodypaint, you can larn to work with it. If you don't, and the invstment is too large, you may want to get UVMapper, which is a very good app. In there, you can move points of your uvmap, you can relax certain portions so that the distortion will become less.
I have tried prudent planning long enough. From now I'll be mad. (Rumi)
ExprssnImg ( ) posted Thu, 21 April 2005 at 11:25 AM
Thank you. I appreciate the simplification and the remedies. I will give both a try. It's amazing how much we've taught ourselves. ;)
