Thu, Feb 13, 7:08 AM CST
Subject: Horizon sharpness - how to fade?
DMM ( ) posted Thu, 21 April 2005 at 7:18 AM ยท edited Thu, 13 February 2025 at 4:03 AM
See the horizon in the image, I can't seem to get it to be anything other than razor-sharp. Increasing & decreasing fog & haze has no effect. Does anyone have any nice tips about this?
yggdrasil ( ) posted Thu, 21 April 2005 at 8:11 AM
V5I? If so, you could probably use the 'Distance to camera' input to control the colour of the sea material, so that it fades towards the horizon colour at extreme distances.
Mark
DMM ( ) posted Thu, 21 April 2005 at 10:26 AM
Yep V5I. Thanks for the tip, but I'd rather have some way of fading the visibility of the land plane. I got a volumetric atmosphere to work, but I lose sky detail (I know, I haven't added the clouds yet ;)) and increase the render time dramatically (I make animations so any increase is compounded by the number of frames).
nanotyrannus ( ) posted Thu, 21 April 2005 at 1:44 PM
You should be able to delete the infinate ground plane to get rid of that effect, I would suggest it anyway as I usually delete it so I can control my horizon line myself with terrains. Anyway, if it's possible for you to do so and get away with it I would recommend that approach.
Collateral_Damage ( ) posted Thu, 21 April 2005 at 2:23 PM
I like the example you did with the volumetric atmosphere but i understand what you mean about render times. It looks like you have not set Fog in Sky. With a standard atmosphere make sure you have the Fog in Sky Thickness set to 100% and max altitude around 20-30. Then set the fog to around 200 with around 20-30% falloff and gather at low altitudes. Tweak max altitude and falloff to get the exact look you want. This is in V5 Esprit, i guess it's same/similar in Infinite?
DMM ( ) posted Thu, 21 April 2005 at 6:00 PM
Bingo - a sticky bun goes to CD :D Fog In Sky indeed fixed it. Funny how you can not see stuff, but when pointed out to you seems totally obvious :D Thanks for the tip ;) Now I just need to fix it again after tweaking it for volumetrics. I seem to have lost some of the nice yellowness of the close trees.
