Attached Link: http://www.renderosity.com/messages.ez?ForumID=12368&Form.ShowMessage=2220646
This looks like it might help you.I have thought about something like that for a long time too. So you are not the only stupid one here Gareth. My proposition is to do it in Photoshop. Create the grayscale image for the rolling hills and then do an extra layer (not lawyer) for the road so that it just slightly modulates the underlying gray levels. Like using "multiply" or something like that instead of "normal" for the road layer. Could do. Another option might be to do a grayscale image for the road "as usual". Then do a terrain in Vue for the hills and overlay the road grayscale in the terrain editor. And play with the percentage of overlay to (hopefully) make it follow the hills. Just my 2 cents, hope someone else has a more clever trick. Could be a dirty trick of course too, Gareth asked for a dirty road anyway.
If you check 'Full blend (cubic bumps)' you should even be able to make a small indentation so that your road doean't look like painted on your terrain. Make sure that the bump value of material 2 is set to -1.
Tried doing what Gareth is asking about several times before. Could never get the material maps to line up with the terrain indent. Didn't think to set the material to object parametric. Thanks much for that screen shot, videodv! That did the trick. The main part of what Gareth is asking, tho, is how to get the path to follow the contours. I've been using 'copy' in the terrain editor to get the image into a paint program. That helps, but its still hard to see exactly how the terrain is shaped. Using the technique recently posted for getting Vue to show contour lines might help. I'll try that as soon as I can find the post.
I could really use some help on this. I have made numerous attempts at this and have NEVER succeeded in finding a way to do this. It is a simple thing, yet sometimes, its the simple things that give us the biggest problems. My problem is that I have never been able to cut a path/road into a terrain that follows the contours. I have played with the flow and strength settings to no avail. All I want to do is create a scene with rolling hills and a dirt road. I dont want the road to look like it has been dynamited through the landscape. I want it rolling with the hills but slightly lower than the banks on either side of it. I cannot find an example to show you, but am hoping that you understand what it is I am trying to do. Any and all help would be greatly appreciated... Gareth:)
