Fri, Nov 22, 2:36 PM CST
Subject: moving the mouth up.
PapaBlueMarlin ( ) posted Mon, 29 January 2001 at 12:42 AM ยท edited Fri, 22 November 2024 at 2:18 PM
I'm new to poser and bryce so bear with me. I have been working on a P4 detective figure for a noir theme I'm trying to develop. I am wondering how to reduce space between his nose and his mouth. None of the morph I've seen on the net move the mouth upwards. I'm trying to make him the most "un-cartoonly" as I possibly can so any advice anyone has would be greatly appreciated. Thanks, PapaBlueMarlin
Jaager ( ) posted Mon, 29 January 2001 at 12:47 AM
Increase your focal length to 55mm at a minimum, 80-100mm is better. ( I like 200mm, but I'm weird.)
PapaBlueMarlin ( ) posted Mon, 29 January 2001 at 1:14 AM
Thanks for the advice Jaager. But doesn't the focal length deal more with the camera than the figure? I change angles (and cameras) so many times to see which I like best. I think a morph might be a little more practical for me. PapaBlueMarlin
Jaager ( ) posted Mon, 29 January 2001 at 11:45 AM
It is a perspective thing. In your attachment , the stem, cutwater and gripe appear much closer and hence larger than the cheeks. Increasing the focal length will put them all in the same relative proportion. You are correct, this has nothing to do with actual morphs, I would be surprised to find that Trav has not already addressed this. Did you look at his site?
PapaBlueMarlin ( ) posted Mon, 29 January 2001 at 7:52 PM
No, I haven't. What is the URL?
Jaager ( ) posted Tue, 30 January 2001 at 12:07 AM
Morph World 2 ? http://morphs.bbay.com/
Jaager ( ) posted Tue, 30 January 2001 at 12:20 AM
If you really do not know about Morph World, then you have some homework to do: Go thru all of Lannie's links: http://3dmodelworld.com/poserlinks5.asp 6 pages of them. This will give you a bit of a view of the resources that are available.
PapaBlueMarlin ( ) posted Tue, 30 January 2001 at 2:36 AM
I've been to Morph World before...just didn't connect it with the name Trav
PapaBlueMarlin ( ) posted Tue, 30 January 2001 at 2:39 AM
I just looked at Morph World again and I didn't see what I was looking for... I'm going to try the other links thru Lannie's...
