Sun, Jan 26, 2:10 AM CST
Subject: Poser rendering and dual core CPUs ?
bucketload3D ( ) posted Sat, 23 April 2005 at 7:02 AM ยท edited Wed, 22 January 2025 at 11:41 PM
Does anyone know how or if Poser support dual core CPUs ? I saw some benchmarks (u can check it here http://www.anandtech.com/cpuchipsets/showdoc.aspx?i=2397&p=19) with new AMD64 dual core cpu and results are impressing - rendering with 3dmax is almost twice as fast,so I was wondering if it's also possible with Poser.
www.Bucketload3d.com - where cool freebies are ~(==^..^)
randym77 ( ) posted Sat, 23 April 2005 at 9:55 AM
No, Poser doesn't support dual CPUs. However, a lot of people like two processors, because you can multitask then. Let Poser use one CPU to render with, while you use the other to surf the Web, play Solitaire, whatever.
jwiest ( ) posted Sat, 23 April 2005 at 10:37 AM
I don't have dual CPU's or dual cores. But I do have a CPU with Hyper Threading that acts like two procs. It's very nice to be able to start a render off and go do other things. :)
John
bluecity ( ) posted Sun, 24 April 2005 at 3:29 AM
FYI: "Hyper Threading" must have programs written for it to take advantage of it just like a dual processor set up - I don't think it would help you at all in Poser. You are still using system resources while you render it you launch another application; in fact, most higher end PCs can run other programs in the background while rendering.
randym77 ( ) posted Sun, 24 April 2005 at 5:58 AM
You can do other things while rendering, but you're taking a chance. It's really glitchy, slow, and unstable. Poser will often lock up, unless it's a really simple render.
No so with dual processors, real or virtual. It's very stable, if slower.
At least, earlier versions of Poser are slower with hyperthreading. (Because they aren't written to take advantage of hyperthreading.) Poser 6 is supposedly not slower. It's not faster, either, but it's not slower.
