Tue, Dec 24, 7:50 PM CST
Subject: Specular and transparency
DigiCalimero ( ) posted Sun, 24 April 2005 at 6:17 PM ยท edited Tue, 24 December 2024 at 7:43 AM
Is there a way in P5 (or 6) to make the specularity not show through transparent surfaces? What I mean is, say I have a plane and it's transparency mapped so only half of it is visible, but the specular shines on the entire plane, which I don't want...
OrcaDesignStudios ( ) posted Sun, 24 April 2005 at 6:25 PM
Plug the transparency map into the "Specular Value" node as well as the tranparency node. It will work like a mask, so that only the white parts of the map will have specularity.
DigiCalimero ( ) posted Mon, 25 April 2005 at 2:56 AM
Excellent! Thanks for tip :-)
caulbox ( ) posted Mon, 25 April 2005 at 4:07 AM
Great tip! Thanks also. I didn't know this either, and it's a problem I've often found to be annoying. Off to play with this idea now.
OrcaDesignStudios ( ) posted Mon, 25 April 2005 at 8:19 AM
No problem. You can use this kind of trick for a lot of different effects. I did a little tutorial on masking nodes that you can find in the tutorials section.
