Erm, foleypro, isn't that better quality thing at odds with the "pixel for pixel its the same output render" thing that we'd heard for quite a while?
If they've improved the render, thats fine by me :), but just a bit different to what we'd been told is all.
edit - off to go read the most recent blurbs to see what they have ended up doing to the rendering side of things. If they have managed to improve quality and reduce times by 30% on average (and some scenes I remember them saying go a lot faster than 30% quicker), I'm impressed - thats some serious algorithm tinkering.
Message edited on: 04/29/2005 09:53
Digital
WasteLanD
I don't see the diff. Is there a difference?
<strong>bandolin</strong><br />
[Former 3DS Max forum coordinator]<br />
<br />
<a href="http://www.renderosity.com/homepage.php">Homepage</a> ||
<a href="http://www.renderosity.com/mod/sitemail/">SiteMail</a> ||
<a href="http://excalibur.renderosity.com/mod/gallery/browse.php?user_id=70375">
Gallery</a> || <a href="http://www.renderosity.com/mod/freestuff/index.php?username=bandolin">
Freestuff</a>
<p><em>Caution: just a hobbyist</em></p>
Yeah, but its doing twice the work in about the same time...hence twice as fast. Looks like a fair bit has changed under the hood.
Digital
WasteLanD
Officially its an upgrade - they've killed off some of the bugs, done some tweaking, and added a bit more functionality in a couple of areas.
Digital
WasteLanD
As you can see, there is very little difference, especially around the window area. I'd bet if you compared two 5.01 renders of the scene you'd see a similar difference check result, especially if the check is run on a JPEG compressed version, as with these (compression will emphasize any slight render differences).
The render report for the 5.01 render doesn't make any sense. It looks like there's some kind of error, so I wouldn't read too much into the figures that do show.
Message edited on: 04/29/2005 12:11
I didn't see much difference in my images at all. Both were saved under exactly the same bryce default saving and compressed together in the image above. PJF, I only see a black image with some words scrabbled on top left?
Creations, when you run a difference check in an image editor any pixels that are the same will be rendered black. Only different pixels show up. The reason you see a primarily black image is that the two scenes are nearly identical. Obviously there are differences where you wrote the version numbers in, and what you see (scramble) is the result of those differences. Obviously I only compared the left hand side of your renders, since most of the other side is covered by the render report.
There seems to be grumbling about the render times in the DAZ forums. There is a post that "image" based textures give the biggest render boost. They also state that DAZ found out why Corel was not supporting the MAC version since the improved code only works with Intel processors and Nvidia cards. (at least thats the way I read the posts.) So single processor users of Bryce 5 using procedural textures may see very little improvement and in fact may see an increase in the render times. I will be very curious to see the outcome of this.
Message edited on: 04/29/2005 14:20
Message edited on: 04/29/2005 14:22
Bryce is acting like a politician. You can never get a clear-cut answer. I read and reread this post and I'm confused. Shouldn't 5.5 be the clear winner? Or at the very least, its renders should be much better. PJF's difference check pretty much confirms NO difference between the two. So, what is 5.5 really offering. Not render speed or quality that's for sure. And if its not offering that (the most sought after features) DAZ should rename Bryce 5.5 to Bryce 5.05. Don't try and dazzle me with new revamped features and promises of faster renders when they don't exist and then try to sell me some 3D pack at $8 cheaper and package it as a special offer. I'm in advertising, I spin this kinda BS everyday for all kinds of products. The truth is in the pudding people. Don't believe the hype. I encourage more testing but so far I'm not impressed.
<br />
Freestuff</a>
I agree, but I guess much depends on other factors, like background processes. That is why I rendered my image in both versions many times. During one of these testrenders I had Poser Pro running also and it slowed down Bryce 5.01 considerably (10 minutes), while Bryce 5.5 did it in 7 minutes. In another testrender there was no other program running and Bryce rendered it in 5 minutes only. Overall, depending on memory allocation in most of the cases Bryce 5.5 rendered defenitely faster, allthough I can't see the difference in the quality of the renders.
For an accurate comparison of render speeds you must keep the conditions as similar as possible. Running 5.01 and 5.5 simultaneously, or with other apps running, may tell you something but it won't tell you anything valuable about their relative speeds. Creations's comparison of Bryce5 running alone vs Bryce5.5 running alone seems to result in times that are in the ball park of what DAZ is saying should be expected. Five minutes, seventeen seconds is a substantial speed improvement over eight minutes, forty four seconds. You'd have to have a fairly big jump in processor power to get that improvement in Bryce5.
Yeah, but its doing twice the work in about the same time...hence twice as fast. Unfortunately no-one cares how many rays the render calculates if the total rendertime isn't going down and/or the render result isn't better.
(_/)
(")(")This is Bunny. Copy and paste bunny into your
signature to help him gain world domination.
You need to start in Bryce 5.01 Render and then save and Open in 5.5...Then render and save then run the same Test backwards open the scene in Bryce5.5 first render and save then 5.01 and save...Now if you use Lights in 5.01 then you need to turn off the Gel light in 5.5 when doing this test Because of the Gel light Bug that was fixed in 5.5...
I must say that I'm really not impressed with what I see about Bryce 5,5. 80,00 US (105,00$ Canadian) for upgrading a software that I allready have and I don't need the content and the Daz Studio. Daz may had to rebuild all the application but it is none of my bussiness and I don't have to pay for that. I'll stay with Bryce 5,01 or simply switch to Vue if Bryce 6 is not better than E-On Software v5. I love Bryce and its GUI but it's a shame to render a Poser image in 3 hours with Bryce vs 15 minutes with an old version of Cinema4D (v6) or a free version of Carrara Studio (v1,1). It is my point of vue for the moment.
Liked it my image "View on Haarlem" was the installer image. :-)
On first view, after launching no big changes.
The extra content package looks promising.
I dragged my Bryce 5 object-, texture- and skylibraries to Bryce 5.5 and all loaded well, no errors in Bryce 5.5.
I like it the taskbar is not locked anymore in Bryce 5.5.
I loaded an old Bryce 5 file (see image), which took 5.01 minutes to render and anti-alias in Bryce 5, but it took 7 minutes in Bryce 5.5. So I don't know about that.
My pc 1.7 Ghz, 512 Ram, 120 gega disk, windows XP, but a louzy 32 Mb graphics card. Plan to upgrade soon (Poser 6 doesn't run on my machine).
My gallery @ Renderosity
