Sat, Feb 8, 4:20 PM CST
Subject: Poser 6 hangs no decimal points,
Barshow ( ) posted Thu, 05 May 2005 at 9:02 PM ยท edited Sat, 08 February 2025 at 4:03 PM
Because Poser 6 hangs I have been using Poser 5 and I must say I just love it , But I have found one other bug in it, or my computer, witch stops me from getting the results I would like. The problem is this, when I go into the Material Room, and try to adjust any dial knobs, the Program hangs, I can change colour and use the plugins, But can't move dial settings. I.E. Reflection_Value. and so on. Just one other thing I would like to add I have noticed that in both Poser 5 and Poser 6 the decimal points are missing in the Material Rooms and in the preference area in Poser 6. When I try to adjust these dials in Poser 5, the program hangs. I checked that using both Canadian English and US English language set-up, and a US keyboard. I also checked that Windows has all its fonts correctly installed as far as I can see. But anyway, I guess without the decimal points, the program doesn't know what to do. If you have any feed back on this, I would appreciate it. I am useing a A8N-SLI Deluxe Motherboerd with Nvidia Drivers up to date. Barry
Fazzel ( ) posted Fri, 06 May 2005 at 10:05 AM
Wow, that is an odd problem. What units are you using in your setup? Try changing that around. Start with Poser Natural Units and see if that does anything. Or if it is already set to that, try some other units of measurement and see if that does anything.
Barshow ( ) posted Fri, 06 May 2005 at 8:16 PM
Oooo gooded."This is a know issue and the engineers are working on a fix. The first service release, which will be out shortly, will have the fixes along with a few others." I got a replie from CL and thats what it said. you know its hard to type with your fingers crossed. Barry
Barshow ( ) posted Fri, 06 May 2005 at 8:20 PM
Thanks Fazzel yep did that, still the same. CL says a fix is on the way . Barry
