Thu, Nov 28, 10:09 PM CST
Subject: Question about Don and Judy skin color in Poser 5
caligula20171 ( ) posted Sat, 07 May 2005 at 6:35 PM ยท edited Thu, 28 November 2024 at 9:23 PM
I have created several characters from Don and Judy for a couple of illustrated novels I am working on. However, I have not figured out how to make the body skin color match the altered color for the figure's morphed and modified head. Is there a way to reset the skin color for the body of a Don figure to match a modified face? Edward -EC-
fls13 ( ) posted Sat, 07 May 2005 at 6:53 PM
I assume you are using the face room for this. If so, there are a few alternatives, but you need a photo application like PhotoShop, PicturePublisher or Gimp to adjust the RGB colors of the images. You can either adjust the finished face texture colors to match the body texture you are using or match the body texture to the face and save it separately from your default body texture. Or, you can adjust the front and profile pic colors to the body texture before you even load them into the face room. Any questions?
caligula20171 ( ) posted Sat, 07 May 2005 at 7:29 PM
Yes...FaceRoom is what I'm using, and I am wondering why on earth FaceRoom doesn't automatically create the body skins to match the new face. I would be using Corel PhotoPaint to alter the bitmap files. I have used PhotoPaint to create backdrops for my scenes and alter some downloads to make colors more suitable for my renders. I presume that I would need to save the image under a new filename, and am wondering what directory I would need to save to and how I could make sure make a bitmap file that I can access once I re-open Poser. Thanks for your help on this...
LostinSpaceman ( ) posted Sat, 07 May 2005 at 7:43 PM
Add my request for this future feature of the faceroom to Poser 7! The face room really SHOULD be able to match the color to the default body texture somehow. Either that or the faceroom texture default needs to be altered to match.
xantor ( ) posted Sat, 07 May 2005 at 9:03 PM
You can change the face colour to match the body, but that tends to make the face texture less distinguishable. If they can do that, it should be fairly easy to make the body colour the same as the face.
LostinSpaceman ( ) posted Sat, 07 May 2005 at 11:16 PM
The real point I think he and I would like to make is there SHOULD have been a body texture included that already MATCHES the faceroom textures.
DCArt ( ) posted Sun, 08 May 2005 at 1:21 AM
The face room really SHOULD be able to match the color to the default body texture somehow. When you apply the texture to the head, Poser asks if you want to adjust the face texture to match the body texture. Are you still having problems getting it to match?
Virtua36 ( ) posted Sun, 08 May 2005 at 4:18 AM
You need SR4 for this option to work.
LostinSpaceman ( ) posted Mon, 09 May 2005 at 11:50 PM
Well I'm using Poser 6 and I can still see a line along the neck even when it asks that question.
caligula20171 ( ) posted Tue, 10 May 2005 at 12:34 AM
I am not familiar with SR4. What is it?
xantor ( ) posted Tue, 10 May 2005 at 1:08 AM
SR4 is service release 4, available at curious labs. It is for poser 5 only.
