Wed, Nov 13, 6:31 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: Wacro: Move "Gradient Bump" to "Bump"
nruddock ( ) posted Sun, 08 May 2005 at 8:06 AM · edited Tue, 12 November 2024 at 6:10 AM
file_235599.txt
A Wacro to move what's plugged into the "Gradient Bump" input to the "Bump" input.
Asks for a value, which is set on the "Bump" input of all altered materials.
N.B. value will only show as entered when the default units are Inches, as Poser applies it's conversion factor when other default units are selected.
Assign to a Wacro button to get multi-material action with Shift-Click.
Run from the File menu or Script Palette to alter all materials for currently selected figure.
Should be Mac friendly as dialog is not tkInter based.
nruddock ( ) posted Sun, 08 May 2005 at 8:08 AM
file_235600.txt
A Wacro to move what's plugged into the "Bump" input to the "Displacement" input.
Asks for a value, which is set on the "Displacement" input of all altered materials.
msg24_7 ( ) posted Sun, 08 May 2005 at 4:16 PM
I should have come across this thread earlier today :-)) Those wacros will be in use all the time! Thanks!
Yesterday's the past, tomorrow's the future, but today is a gift. That's why it's called the present.
kirisute ( ) posted Fri, 07 October 2005 at 5:35 AM
outstanding! if this works as i hope it will i will formally worship you as a God! LOL
destro75 ( ) posted Thu, 13 October 2005 at 12:21 PM
Wow, this is great! I was just thinking of working on something very related to this! Thanks a lot!
