Mon, Jan 20, 12:00 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Python Tutorial for Beginners
JeffH ( ) posted Fri, 02 February 2001 at 12:49 PM · edited Mon, 20 January 2025 at 9:19 AM
Attached Link: http://www.honors.montana.edu/~jjc/easytut/easytut/easytut.html
Just to start things off: http://www.honors.montana.edu/~jjc/easytut/easytut/easytut.html -Jeff H.
Marque ( ) posted Fri, 02 February 2001 at 1:05 PM
Thanks! Got in pdf now. 8^) Marque
