Photography F.A.Q (Last Updated: 2024 Nov 13 3:04 pm)
Sheila, When you use MACRO mode it allows you to shoot closeups images in a specified range (depending on you camera model and it optical zoom) On my G6 in Macro mode, I can shoot from 2 inches to 1.6 feet at the wide angle end and .5 ft to 1.6 feet at the telephoto end. As I understand it Macro and closeup photography are pretty much the same. Macro is used to get fill the frame of small objects as much as possible. Joe
The depth of field will be less the greater the focal length you use. Therefore if you want to put a background out of focus by having a shallower depth of field then use the zoom from further away and it will do this. This is one reason people use macro lenes for portrait work. You should keep in mind that it could get to be a very shallow depth of field on full zoom therefore you may not get the full subject in focus. Notice how davidy's shots all have a very out of focus background. As above your macro focus on your camera will have a range though which you must stick to.
Message edited on: 05/09/2005 17:14
And every one said, 'If we only live,
We too will go to sea in a Sieve,---
To the hills of the Chankly Bore!'
Far and few, far and few, Are the lands where the Jumblies
live;
Their heads are green, and their hands are blue, And they went to
sea in a Sieve.
Edward Lear
http://www.nonsenselit.org/Lear/ns/jumblies.html
thanks guys! i guess i just always assumed in order to use macro setting i had to always be very close to my subject. i can't remember how far away i was standing from the flower, but kemal says he thinks it was 4-5 feet. i didn't zoom in all the way...just some. Davidy, your pictures are really fantastic!!!! Mireille, i wasn't using my ring flask in these either. i usually do. Interesting that you regularly use this kind of setting for macro shots. i just had no idea it would work! Richard, good point about needing to be careful about DOF. My DOF is not good in either of those. i'll have to look tomorrow to check out the rest of them. Joe, thanks for explaining...i'll read more in my manual later. i appreciate ya'all taking the time to explain and give me feedback!!!!! i post a couple that kemal took using this technique, then it's to bed. i'm totally exhausted.
