Thu, Jan 23, 3:36 AM CST
Subject: Does Poser 6 have Network Render Functions?
Angelouscuitry ( ) posted Mon, 09 May 2005 at 7:04 PM ยท edited Thu, 23 January 2025 at 3:31 AM
Still looking for reasons to buy?
kaveman ( ) posted Mon, 09 May 2005 at 7:30 PM
No, sorry. You could break up your animations and run a set of renders on different computers then join it all together. That would require a Poser Licence for each computer and the required Runtimes available either locally or across the network.
Lawndart ( ) posted Tue, 10 May 2005 at 12:36 AM
What kaveman mentioned is what I do. I break my scenes up and render over 8 machines. I render each frame as an image and put the sequence together in After Effects. If this is the reason you would buy then save your money. You could do that with Poser 2 if you wanted to. There are plenty of other reasons to buy P6.
Angelouscuitry ( ) posted Tue, 10 May 2005 at 8:05 AM
I'm not so concerned with animating as just getting a descent size, I'm trying to get a life sized render out of poser!
Lawndart ( ) posted Tue, 10 May 2005 at 1:09 PM
I see. You would like to be able to farm out portions of the image to differant machines. My solution definately won't help with that.
