Tue, Jan 28, 5:30 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Itty-Bitty Script #2
bushi ( ) posted Sat, 03 February 2001 at 8:28 PM · edited Mon, 27 January 2025 at 7:26 AM
Attached Link: http://bushi3d.com/PythonScripts/ibscript2.py
Here's another small PoserPython script. This one is a bit more interesting. It changes a figure's head MT parameter dial values to random values from 0 to 1. There's also a tweek constant that you can change to produce negative values. As before, I'd like to hear from anyone that tries it on a Mac. BTW don't use this on anything but 'junk' figures since ALL the head MT parameter values will be changed
JeffH ( ) posted Sun, 04 February 2001 at 5:15 AM
Heh, sort of a face randomizer? Have you tried to create any geometry (props) with Python yet? -Jeff
jbrugion ( ) posted Sun, 04 February 2001 at 9:56 AM
Need to remind newbies that the "Undo Change" doesn't work with stuff changed by Python scripts. Something that will need to be worked into production scripts.
poserpro ( ) posted Sun, 04 February 2001 at 9:59 AM
cool random mt for posette's head. thanks
poserpro ( ) posted Sun, 04 February 2001 at 10:05 AM
this can be used to generate various of FACE(fc2) for the head. COOL.
poserpro ( ) posted Sun, 04 February 2001 at 10:07 AM
i just changed the actor name to chest, hehe see what it does to her breats :P
bushi ( ) posted Sun, 04 February 2001 at 2:56 PM
As to reseting the MTs back to 0, just remove the random function in the next to last line. change: SingleActor.SetParameter(SingleParameter.Name(),(random.random()+TweekValue)) to: SingleActor.SetParameter(SingleParameter.Name(), 0.0) That will reset all the changed MT parameter dials.
poserpro ( ) posted Sun, 04 February 2001 at 3:15 PM
cool:) How to "set" and "set" multiple MTs at a time ? and How to "reset" multiple MTs at a time ? for ex, I set chest , head, abdomen at a *py click and rest them back to 0.0 TIA
poserpro ( ) posted Sun, 04 February 2001 at 3:17 PM
oops:P cool:) How to "set" multiple MTs at a time ? and How to "reset" multiple MTs at a time ? TIA
bushi ( ) posted Sun, 04 February 2001 at 3:58 PM
As far as this script is concerned, you could select multiple actors by changing the if statement. change: if SingleActor.Name() == 'Head': to: if (SingleActor.Name() == 'Head') or (SingleActor.Name() == 'Chest'): Now all the MTs for the Head and the Chest will be selected. You could make this script much more generalized by using some of TkInter's widgets. There's one called 'CheckButton' that gives a panel with selectable boxes. I haven't tried building one of these with actor names at runtime but I'd think it could be done. Jeff - No, I haven't tried that yet. I've looked at the examples and it looks like it's fairly straight forward. I need to get a bit deeper into the examples before trying it though.
poserpro ( ) posted Sun, 04 February 2001 at 4:15 PM
thanks, I did a "set" and "reset" multiple MT.py. But what if I like to set all , and reset all ? TIA.
bushi ( ) posted Sun, 04 February 2001 at 4:38 PM
That's easy. If you comment out the if statement (put a '#' in the first column of the line) then ALL actors will either get or reset.
poserpro ( ) posted Sun, 04 February 2001 at 5:01 PM
wow, thanks. It works :)
poserpro ( ) posted Sun, 04 February 2001 at 5:04 PM
hope there will a python to get rid of the unnecessary bones in SETUP with a l single click:P
poserpro ( ) posted Sun, 04 February 2001 at 5:23 PM
let me explain this, for example, if we need to delete all the finger bones in both hands, using delete will be tedious, so I figure if there is a custom py to delete all the fingersd leaving only hand parts. TIA.
poserpro ( ) posted Sun, 04 February 2001 at 5:26 PM
it seems one can't undo the py after hitting a py buttons in python scripts panel.
JeffH ( ) posted Sun, 04 February 2001 at 5:39 PM
That's true, there is no undo for a script.
bushi ( ) posted Sun, 04 February 2001 at 5:47 PM
I haven't looked through the PoserPython docs to see if there are any functions related to the setup room so I'm not sure on that point. As to undoing scripts, I'm certain that as the scripts get more complex there will be undo functions built into them. Actually that would be relatively simple. It's just a case of saving the current state of the actors before changing them. An undo would just reload the saved values.
poserpro ( ) posted Mon, 05 February 2001 at 4:18 AM
The Random MT py ( for head alone) turns out a good tool to create many convincing facial expression or new looks. It is a very import ant tool now. the reason is simple, normally we have to manually adhust the parameter dials to achieve new looks or expresson, with trial and error, it takes time. But with the random MT py, it is very quick and easy way to get many random sample and part of them are very useful to save as spawn morph or fc2. I found the tweekValue is a key to the ramdom effects. so changing it may result in different combination of MT. Thanks to Bushi who enlighted me for the py.
poserpro ( ) posted Mon, 05 February 2001 at 4:25 AM
the reason for asking an undo is becasue when i hit the random mt py, i kept hitting unaware of a mt is very good to save as spawn or f22, but i was too quick to hit next so i failed to keep it and ctrl + z has no effect on this:( btw, anyway to make an incremental MTs, i mean with one py hit, the dials will increase the amount for say 0.001( or any ) so that i can see the increasingly morphing effect. TIA
bushi ( ) posted Mon, 05 February 2001 at 11:18 PM
Yes, I could add an undo (at least 5 or 10 layers deep) and an incremental parameter change. Actually it would be good practice since it will require some TkInter programming to do it. I've also been thinking about adding a symmetry feature. That would be where selected parameter dials would get the same random adjustment. As an example, having the 'blink' parameter be set the same for the right and left eye.
