Mon, Dec 2, 10:58 PM CST
Subject: Python script to delete all lights that are turned OFF
RGUS ( ) posted Sun, 15 May 2005 at 5:10 PM · edited Mon, 02 December 2024 at 5:06 AM
Ok you Python guru's, I constantly load preset light sets to see effects in my scene, but after a while I have all these lights that I've turned off and don't need them cluttering up the scene. Is there a python script out there that will delete all lights in a scene that are turned "OFF"? I've got scripts to delete all lights no matter what and delete lights below a certain intensity, but these don't allow selection of lights turned "OFF" Thanks you guys that write this stuff... I thought "Python" was part of the "Monty Flying Circus" series... LOL
nruddock ( ) posted Sun, 15 May 2005 at 5:30 PM
What version of Poser is it for ?
RGUS ( ) posted Sun, 15 May 2005 at 5:41 PM
Poser 6, if that helps... thanks
Acadia ( ) posted Sun, 15 May 2005 at 5:51 PM · edited Sun, 15 May 2005 at 5:57 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=2157525
Hmmm, there is one in the free stuff, but I can't remember who made it. EDIT: I dug up the thread where I asked about the same thing. There is a link in there to a script or utility
Message edited on: 05/15/2005 17:57
nruddock ( ) posted Sun, 15 May 2005 at 6:30 PM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12390&Form.ShowMessage=2261347
Your in luck then, as there's now an Actor method to detect whether a light is on or off (link is to Poser Python forum).
zulu9812 ( ) posted Sun, 15 May 2005 at 6:54 PM
Didn't Ockham do something for this? I believe it's in his free stuff section, and it's called Light Panel
RGUS ( ) posted Sun, 15 May 2005 at 8:17 PM
Thanks everyone, this is great to see the feedback... "nruddock", I went to you link, but couldn't get the script to work, I'm sure I'm missing something...
RGUS ( ) posted Sun, 15 May 2005 at 8:25 PM
Again thanks everybody... I don't know why, because I don't write Python code, but being a hacker from way back, I decided to have a go at mixing code and seeing what happens.... It works... don't know why or how, but this little bit of Python, deletes all lights in a scene that are switched off. This makes it easier to work with only the lights you want and not have to manually delete the ones you don't want. [Code starts:] import poser scene=poser.Scene() lights=scene.Lights() for lig in scene.Lights(): if not lig.LightOn(): lig.Delete() [Code Ends:] Just say it as "DelOFFLights.py" or anything else you like and run it to delete "OFF" lights
Eternl_Knight ( ) posted Sun, 15 May 2005 at 9:43 PM · edited Sun, 15 May 2005 at 9:43 PM
Remember to actually put the spaces/tabs into the code!
For example - the code should be something like the following:
[Code starts:]
import poser
scene=poser.Scene()
    lig.Delete()
[Code Ends:]
Message edited on: 05/15/2005 21:43
nruddock ( ) posted Mon, 16 May 2005 at 12:42 PM
Strange, it works for me without the "import poser" line. I've been including it in previous P6 scripts as it did seem to need it.
DocMatter ( ) posted Mon, 16 May 2005 at 1:24 PM
bookmark
