Thu, Nov 14, 5:23 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 13 11:02 am)
Subject: Is UV Mapper....
Rose ( ) posted Sun, 04 February 2001 at 11:46 PM ยท edited Thu, 14 November 2024 at 5:09 AM
Attached Link: Only Poser?
only supposed to be used in conjunction with Poser (oh, gosh - I hope not). Unfortunately I'm still using Poser1
iNSEcT ( ) posted Mon, 05 February 2001 at 1:30 AM
nope i use uvmapper with 3dsmax 3.1 and 4.0 all the time without any probs, cant speak for any other apps though but i dont see why it wouldnt work
iNSEcT ( ) posted Mon, 05 February 2001 at 1:31 AM
i meant to add, if your trying to uvmap something are you resaving the model from uv mapper itself? after you import the obj, and then map it you have to export the obj and the texture map as well...
JeffH ( ) posted Mon, 05 February 2001 at 6:05 AM
Attached Link: http://www.curiouslabs.com
If you have Poser1 you might as well go to the Curious Labs site and buy the upgrade to Poser4.
Rose ( ) posted Mon, 05 February 2001 at 4:09 PM
Attached Link: http://members.aol.com/Roseb44170/graphics.htm
i meant to add, if your trying to uvmap something are you resaving the model from uv mapper itself? after you import the obj, and then map it you have to export the obj and the texture map as well... << No, following the instructions I save the model as something new and also save the bitmap as well. I tried to use it in Bryce as well as Rhino but its not mapping correctly. I get a lot of empty spaces.
JeffH ( ) posted Mon, 05 February 2001 at 4:17 PM
What mapping mode are you using?
