If you're unfamiliar with the Group tool, I suggest practicing with a low poly model to get the hang of it. A standard six poly cube would be too simple, but perhaps you could construct one with more polys per side. You'd be able to toy with it without having too many polys and vectors to deal with. Using the appropriate document display is also crucial. For example, the wireframe will allow you to select polys through the mesh, whereas the flat shade only allows direct selection of the poly you're clicking on. As Little Dragon pointed out, you could select the entire surface of the cone, barring the extreme ends, select "Create Prop" from the Group tool options, and then delete the original cone, leaving you with a truncated cone (like a megaphone). Select the surface of this new cone and "Assign Material" to give it a material zone. By selecting various areas, you can create various material zones. If you want to keep this new cone/lampshade prop for later use, don't forget to save it to the library.
Does TS2 come with a delete face tool? I know later versions did. Right click the cone to bring up the vertex edit tool and see if there is one. Failing that use the paint face tool to give the caps a different material colour. Then when you bring the model into Poser you can set that material to have 100% transparency. A further option would be to use the grouping tool to select the base colour and spawn a prop. This would give you the cone without the caps.
Considering the bed. In TS use the paint object tool to give a different material colour to each element. Then in Poser you will be able to apply a different texture to each one.
We have not covered UV Mapping here so its probably worth you taking a visit to www.uvmapper.com to pick up the free light version of the program and look through the excellent tutorials there.
Hope that helps.
Attached Link: http://www.tir.com/~johnwind/Compose11.zip
Or save in COB format and use John Wind's Compose utility.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
I have P5 and I'm using the free version of Truspace. I'm having a hell of a time with 2 issues. 1. "closed" objects. I create a cone, and want to use it as a lampshade in poser, but the ends of the cone are 'capped'. How can I remove all those cap polygons? 2. single groups. I create a bed, which has a frame, mattress and box springs. I export/import to Poser and I can't texture the frame with a different texture than the mattresses. The Poser grouping tool does not work like I'd expect.
