Vue F.A.Q (Last Updated: 2024 Sep 04 4:56 pm)
Thank you - this looks great!!! Peggy
LVS - Where Learning is Fun!
woo, awesome thanks for that :)
"I'd rather be a
Fool who believes in Dragons, Than a King who believes in
Nothing!" www.silverblades-suitcase.com
Free tutorials, Vue & Bryce materials, Bryce Skies, models,
D&D items, stories.
Tutorials on Poser imports
to Vue/Bryce, Postwork, Vue rendering/lighting, etc etc!
Will this script work for PSP version XI? I tried it, but got an error - Maybe I need to read the documentation better.
Anyway, still need to work on the materials. When I use an eco material, it tends to fill in parts of the track. How do I get it to stop that?
Peggy
Hi, Peggy...
Just a thought re: eco-system problem.
I'm not all that familiar with the usage of PSP (I have PSP 9 btw), but...
I assume you still have the original "road map" that you created in PSP. Why not take that (and just that - not the terrain-map or anything), select the road (I assume the "magic wand" would be best for this), expand the selection somwhat (much like the script does for the edges) fill with white and save it as a bmp (or whatever). Then use that in Vue to control the distribution of the eco-system (it may heve to be made negative).... Just a thought.
I've only played with the script for a couple of hors (had some trouble getting it working initially, but eventually worked out what I was doing wrong), but I can see great uses for it:-))
Many thanks to sittingblue for making it available, and at a price I can afford!
Cheers,
Diolma
Attached Link: http://tidbit.freefronthost.com/
Greetings,This is a scene I'm working right now. I'm sharing it, because it illustrates the results you can get with a Roadmaker script I wrote. In this scene, I used Roadmaker to modify the elevation map for the road and the house's lot. Roadmaker also created four material distribution maps used in this scene.
It was some time ago when I started doing some research on creating roads in Vue 4. In the process, I created a Paint Shop Pro 8 script that greatly helps in creating roads, paths, among other things in Vue 4 and 5.
I call the script 'Roadmaker'. It's fairly easy to use and learn, but at the same time, very dynamic and customizable.
One run of the script creates three material distribution maps: Road, Roadside, and Road Tracks, and a revised elevation map corresponding with the material maps.
I am making the script freely available on my website. Plus, I also wrote a tutorial on how to use the Roadmaker script.
The Roadmaker tutorial's address:
http://tidbit.freefronthost.com/tutorials/roadmaker/index.htm
My Roadmaker Kit comes with the Roadmaker script, a Roadmaker Prep Map script, and two Vue 5 Infinite materials that are great starting points for Roadmaker.
The Roadmaker Kit's address:
http://tidbit.freefronthost.com/objects/index.htm
I hope you enjoy the script and making roads as much as I do. If you have any questions, please feel free to post them here or to send me an instant message.
Charles
Charles
