Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 5:20 am)
I had the exact same problem. I was using the "Square Hi-Res" in the Props -> Primitives library. I loaded up the "One Sided Square" from the Props -> Primitives library and the problem went away. FYI, Clint
Clint Hawkins
All my life I've been over the top ... I don't know what I'm doing
... All I know is I don't wana stop!
(Zakk Wylde (2007))
That is the best solution, using the single sided square.
But if you absolutely, positively MUST use the double sided
or hi-res square, adding a tiny amount of displacement in the
material room to the square and in the render setting checking
on Use Displacement Maps and setting Min Displacement Bounds
to 1.000 will also do the trick.
The problem is that if the front and back side are too
close together, you end up seeing parts of both sides.
Displacement gives the front and back side enough separation
that you only see on side. Of course with a single sided
square there is only one side to see, so you don't get
that problem.
Wow, poor guy went through all that trouble, wiping out
his P6 and reloading it for such a simple little problem.
I feel sort of sad for David.
Attached Link: Setting the displacement
This is an old problem from P5 that was never fixed. Attach the displacement node to the texture map and set the displacement value to 0.01 For pictures see link ;-)Gill
![file_243609.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_243609.jpg)
I was having problems with pure white walls having all sorts of strange patterns when I went from DRAFT to FINAL mode in the FireFly render engine. I started to walk through turning things on using a fresh scene. When I get to the third setting from the left in the Auto Settings which turns on Cast Shadows, the white square behind the figure goes crazy.I have been able to reproduce this problem consistently using OpenGL and SreeD and by shifting to Manual Settigns and toggling shodows on and off.
I am using a Dell XPS Gen 4 with a NVIDIA GeForce6800 GTO (driver version 6.6.8.7, 11/04). According to the WIN system monitor utility, I have plenty of memory during all of my renders.
I have done a wipe and reload on P6. I do not have any indication that a wipe and reload is needed for WIN XP (everything else and even P6 runs great outside of this problem).
Anyone else having this problem? It has effectively stopped my P6 work dead.
