Tue, Feb 11, 12:10 AM CST
Subject: A small question that needs an answer please:
Belgareth ( ) posted Wed, 25 May 2005 at 8:12 AM · edited Tue, 11 February 2025 at 12:06 AM
A small question... How (look at attached image)are the colours in the Altitudes mapped to the terrain. I wish to map them to a terrain in the world view. I have found the colour maps, but cannot seem to get the mapping mode right.
Any help would be great... Thanks...
Gareth:)
Belgareth ( ) posted Wed, 25 May 2005 at 8:14 AM
2nd time lucky...lol
agiel ( ) posted Wed, 25 May 2005 at 8:42 AM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12368&Form.ShowMessage=2201199#15
I got close to what you want when I was playing with contour lines on a terrain. Check out the link. You will need to connect Altitude to a Color Map node with your gradient, using a Brightness/Contrast filter and then play with the values of the filter to stretch your color map between the lowest and highest altitudes on your terrain.
Belgareth ( ) posted Wed, 25 May 2005 at 9:40 AM
Thanks, agiel. I think your examples are close to why I asked this question in the first place. I want to drive my eco using the colour map. The colours seem to look and map so well in the editor that If I could get it working like that, I could start to work on a way to drive the Eco using them.
nanotyrannus ( ) posted Wed, 25 May 2005 at 11:23 AM
The other thing you could do is heavily mix the material and make those materials altitude dependent, I have a few materials that do this that are 10-18 pairings deep that I've had great fun with doing ecosystems with, see the example I attached for the base materials, I'll attach the ecosystem render shortly. Basically I have a dark green material applied to the lowest elevations, fading up to a lighter green material and rising up to sand/dirt and ending in a snow/rock combo.
nanotyrannus ( ) posted Wed, 25 May 2005 at 11:26 AM
Here's the ecosystem render, I've got regular green maples mapped to the dark areas and added red and yellow maples for the light green areas, just be warned, I got a "limiting performance" message when I added all those trees to the ecosystem, but it was definately worth it. Ecoystems are insanely cool!
ckeyes ( ) posted Wed, 25 May 2005 at 11:31 AM
Hi Nanotyrannus, That's a great terrain! I'd like to make something similar. Is that something I could do in Vue 4, mixing terrains for different elevations, and might you have a sample I could learn from? I'm still new to alot of that type of stuff. Thanks, Carl
Belgareth ( ) posted Wed, 25 May 2005 at 11:43 AM
That is a beautiful example. I wish I could do something like that. Are/would you be willing to make the mat available for download.
nanotyrannus ( ) posted Wed, 25 May 2005 at 12:02 PM
Carl - The terrain itself is actually a 3 meter resolution dem file downloaded and compiled from the USGS and imported into Vue 4 Pro / 5 Infinate (importing into Vue 4/5 Esprit the terrain has to be chunked down because of some sort of terrain import limitation that e-on neglected to mention as being part of the esprit lineup. Because it can only be imported wholly in Vue 4 Pro I have exported it to a bmp format that you should be able to import into Vue 4 Esprit (you may have to do some resizing as the terrain is not perfectly square) and it probably isn't going to be the same resolution as what I was able to get in Vue 4 Pro (7082 x 4928) But it would be a start. The other side is I have no way to host these files in the public domain (the bmp terrain file is 34 mb and the texture file is 145 kb) I could email you the texture file as it is only procedural textures, but the bmp of the terrain file is definately too large for emailing.
LordWexford ( ) posted Wed, 25 May 2005 at 12:08 PM
<< I could email you the texture file >> Would you be prepared to put it up in the "Free Stuff" area? I for one would like to be able to study it to see how it works. Thanks, Bernie
nanotyrannus ( ) posted Wed, 25 May 2005 at 12:45 PM
In order to post stuff to the "free stuff" area you have to have it hosted on your own site, unfortunately I don't have that and don't have the time to look into it at the moment, about all I can do is email it at the moment, it's a wholly procedural material so it's small enough to easily be emailed. Let me know. Orion
spider1313 ( ) posted Thu, 26 May 2005 at 6:50 PM
This does indeed look very interesting, Nanotryanus! Welll beyond my scope of understanding at this point, but I would also like to get my hands on it...it would, I think go a long ways toward helping me and possibly others to get a better grasp on this "eco-control" issue? There is an option...yousendit.com...that would enable you to be able to send the entire package w/o having to get into hosting your own site. Just a thought...but will keep my eyes on this thread anyhoo'-)!
videodv ( ) posted Fri, 27 May 2005 at 1:54 AM
Great link spider will come in very handy. videodv.
nanotyrannus ( ) posted Fri, 27 May 2005 at 11:57 AM
I'll check more on it when I have time, thanks for the info, I'll write more here later. -Orion
