Tue, Nov 26, 6:16 PM CST
Subject: Got a major malfunction
markostimpy ( ) posted Thu, 26 May 2005 at 8:02 PM · edited Fri, 22 November 2024 at 9:13 PM
Can anyone tell me why this happened? I was attempting to render a Vue file at 10800 X 8100 at 300 dpi in Final mode. Every system I have tried it on gave an out of memory error after render was done. Even on a system that had 1.6 Terrabytes of memory with 2 gigs of RAM. The bottom portion seemed to start to render fine. HELP !
Mark S. Popham
markostimpy@gmail.com
dlk30341 ( ) posted Thu, 26 May 2005 at 8:18 PM
O.o...I can't render anything over the 5000x5000 limit...and that's just 1 item(a tree) before I get an OEM crash(I have 4g ram).
markostimpy ( ) posted Sat, 28 May 2005 at 10:19 AM
I seem to have worked it out. Dis not know about any limit (5000x5000). Just rendered at 4950x3713, final, at 300 dpi and it seems to be fine. Thanks.
Mark S. Popham
Belgareth ( ) posted Sun, 29 May 2005 at 9:53 AM · edited Sun, 29 May 2005 at 9:55 AM
If you want to render it at 10800 X 8100, your best bet is to "Select Render Area" under Picture on the Toolbar Menu, and divide your picture into blocks (in your mind) and Render selected aria and save, then render the next block/tile and save that. You'll have to stitch them together in Photoshop, but you can render huge images that way. Gareth:)
Message edited on: 05/29/2005 09:55
