Sun, Feb 2, 12:00 PM CST
Subject: Strange Peaks When I use Vue's Plot Path
tebop ( ) posted Sat, 28 May 2005 at 4:41 PM · edited Thu, 09 January 2025 at 12:27 PM
Hello i imported a 2 characters in vue from poser. and i apply a path for them to run on. Each character has his path..but i notice at one point in time..in the path..there is an abrupt Peak..in the Z axis where the characters suddenly are pushed up to the sky..then they go back and it's normal. but what the?? why is this peak in the path happening? anyone know how to fix? thanks
jwhitham ( ) posted Sun, 29 May 2005 at 11:45 AM
I would guess you have your figures passing under a tree, or through an arch, something on those lines? If so, make those ojects invisible before running Mover Wizard, otherwise the figures will leap over them.
Phoul ( ) posted Sun, 29 May 2005 at 12:41 PM · edited Sun, 29 May 2005 at 12:41 PM
Not sure; but try that: in tab display options, deselect the two "Clip object blablabla...". If I've understood well your issue, should work.
BTW, dont' forget, screen captures always could help to help ;-)
Message edited on: 05/29/2005 12:41
