hey looks cool, nice boolean model. the texture looks like a shiny marble, maybe not the ideal for a robot ;). there are several free metal texture here, try to download a couple of them (or try to make a camo texture, should also be cool) laser beams can be added in photoshop, but there is a leser beam texture in the material library, under volumetrics material. remember to add a cylindrical light to the lases beams in order to make it work.
Aye, good stuff! A great model... For laser-beams, simply select one of the cylinders caring out the inside. Duplicate it (Ctrl-D). On the Edit Palette (top), click one of the little triangle tabs below the scaler or mover and select "Object Space". Now pull either Y-axis scaler and stretch the cylinder out along it's long axis. Now, it's just a material game. Try some presets, in the volume section there are a few. You may also need to Duplicate the cylinder again and "Convert" it to a Light using the little lefty-righty arrows on the Edit Palette. Good luck with this, I'll make you a screenshot if this text isn't making any sense...
You've managed to create a robot that is both cute and lethal. :-)
<strong>bandolin</strong><br />
[Former 3DS Max forum coordinator]<br />
<br />
<a href="http://www.renderosity.com/homepage.php">Homepage</a> ||
<a href="http://www.renderosity.com/mod/sitemail/">SiteMail</a> ||
<a href="http://excalibur.renderosity.com/mod/gallery/browse.php?user_id=70375">
Gallery</a> || <a href="http://www.renderosity.com/mod/freestuff/index.php?username=bandolin">
Freestuff</a>
<p><em>Caution: just a hobbyist</em></p>
I actually like that material. The feet ARE a bit small though.
![file_246699.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_246699.jpg)
I dont like the material on this robot, so tell me youre sugestions what kind of "texture" would you place on it. Its all done with booleans. How can I place laser beams on sniper?Open your mind and share the knowledge!
